Question about Janome Memory Craft 9000 Computerized Sewing Machine
Machine wont come on
It seems like theres no electricity going to it my daughter did tell me that she broke a needle the last time it was used i checked the bobbin holder and hook race for lint , threads, and needle parts its clean
  • cathywmartin Jan 26, 2009
    I have the exact problem...broken needle and all. I did not know it had a fuse!!
  • 323 Answers
More than likely you have a blown fuse. If you plug it in,turn it on and nothing happens the fuse is the first place to look. Unfortunately, it is not a simple repair that I'm going to recommend you do. It should go to a dealer who is familiar with this brand of machine and shouldn't cost more than $100 including servicing.
sewman7
Posted on Dec 29, 2008
Why wont my Juki DDL-8700 form a stitch?
machine is out of time and u probably have burrs on the hook since you broke the plate with a needle probably from pulling fabric and bending the needle. you instruction manual will tell u how to time machine and its really very simple. all u have to do is take off feeder plate, loosen the 3 screws that hold the hook then lower the needle with the wheel until the needle just starts to rise. bring the loose hook point to i/16 " fron the needle and tighten hook screws. machine must be tilted back to do this whole operation. it helps to have a short screwdriver to tighten the hook screws. remove burrs with lite emory paper stroking in the sale direction as the hook.
Jun 25, 2014 | Juki DDL-8700
What size needles fit a Rex 26-188 walking foot machine?
16x63 needle system, unless it's been retimed for something else. Suggest you might want to find the dull, bent up or otherwise still intact needle and show it to your industrial supplier or repair person, so they can check for you.
Needle system tells you about the length and timing distance of the needle: see, e.g.: http://designer-entrepreneurs.com/blog/illustrations/Singer_Needle.pdf Size tells you about the diameter of the needle: here's a suite of home sewing machine needles, all of the same needle system, but one of the photos shows a comparison of sizes:
http://www.picturetrail.com/sfx/album/view/17206792
Jan 18, 2014 | Brother XR-65t Mechanical Sewing Machine
My needle broke on my serger and i replaced it and now wont make stitch. please help
some times when you break a needle in a sewing machine or
serger it can cause the machine to jump time, it would be a good
idea to have the machine checked for a timing problem or to see
if when the needle broke it caused a problem with another part in
the serger.
Nov 12, 2012 | Sewing Machines
I have an xl2230.today the needle broke so i replaced with new one,and now the machine wont sew properly,its banging sometimes when it sews and the thread keeps breaking at the needle end and the fabr
try another needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
if none of these things help then I suggest the machine get's serviced just
incase the timing is messed up
May 31, 2012 | Brother XL-2230 Mechanical Sewing Machine
My thread broke and now my needle wont go up or down what can i do?
If the needle wont go up and down at all when you turn the handwheel, it's most likely due to fluff and general muck has got into the basting stitch mechanism - this is a frequent failure on Artista models that have the basting stitch option. Try gently pushing the needle bar up at the same time as turning the handwheel ... with any luck the basting solenoid clutch will re-engage with the hole in the needle bar. If this works, it's only a temporary fix and tells you that your machine is overdue for a service !!!! Getting the gunge out of the basting mechanism needs to be done by a Bernina service agent. Trouble is, some embroidery patterns use the basting mechanism to raise the needle-bar out of the way whilst the hoop moves to a distant point on the embroidery, so if you 'fix it' using the above method, it may well fail again when you try to do another embroidery. Sorry !
Nov 15, 2011 | Bernina Artista 180
My Juki industrial machine will not pick up the lower thread and it wont keep a stitch going. Why wont it pick it up anymore!!! I really need my machine!
hi there
can you please tell me your machine model? i can help
any way if lockstitch machine you must first make sure you installed needle correct way and you are use new needle
can you check hight od needle bar is ok if you move it up and dwon?
can you check timing between needle and tip point for hook?
i can send page from instruction manual how to adjust hight of needle bar and timing with hook.
best regards
ashraf abozid
aabozid@hotmail.com
Sep 02, 2010 | Juki Sewing Machines
Where can I find new needles? (LS-2125 Machine) All my needles broke and I can't seem to find out where to get replacement ones before Halloween! Can I use any machine needles or do they have to be...
If in the uk, any high street sewing shop that sells brother machines will help you, otherwise, check the local yellow pages for sewing machine suppliers and spares.
Oct 25, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer Futura 250E - thread is shredding after 5-6 stitches
no damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Apr 03, 2017 | Singer CE-200 Quantum Futura Computerized...
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Janome Memory Craft 9000 Computerized Sewing Machine Logo
93 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
