Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Smoke fume from canon sd400
My canon sd400 just emitted smoke fumes last week. i took out the battery and all and left it for a week. now when i try to use it the battery only lasts about 20 minutes or even less. can a battery emit smoke like that? should i just replace the battery?
  • Anonymous Mar 04, 2009
    when i use the flash on my canon powershot sd 400 smoke emits from the top of the camera
  • Anonymous Mar 23, 2014
    I brought my camera 6 years before and its only a few months I noticed a problem with my camera of emitting fumes while taking snap shots. What should I do ? Also its getting hot after the fume is emitted .
    Genius:
  • 1,689 Answers
You should send the camera with the battery for service to find out if there is a defect on any internal circuit boards, or if the fault is actually the battery. There is no reliable way for you to determine this yourself, unless you have the proper setup and training to service these cameras.
Jerry G.
Posted on Jan 08, 2009
I would like to know what makes that the Jeep smoke after rearranging the vacuum lines is it the EVAP system on HBO or the engine vacuum lines vacuum lines
the book is free,
and real
and posted here over 300 times, search much.
all that is covered in the SM. (how to put it back as it was new)
no clues as to what the smoke is.
or where it emits from. (tail pipe end)
white smoke or black
black is rich running.
white can be burning oil and smells like burning oil (lingers)
white can be steam,aka, antifeezes burning, goes the vapors dont linger like oil smoke does and smells sweet, unlike oil smoke.
EVAP is only FUEL vent , fumes. gas fumes.
there are lots of vacuum lines
to engine
evap
brake booster
the engine hood sticker covers the majors, (smog related, )
SM , serv. man. click WK and read.
free
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Dec 11, 2016 | Jeep Cars & Trucks
I have problem with fumes from engine entering the passenger compartment,
thank you peugeot 307 ,right look under air filter and their is a pipe from rocker cover going into air filter ,now i cannot remember every car i work on and iam a old dinasaur so memory is lacking but it could be a box on side of engine ,anyway their will be a pipe somewhere from air filter to wherever ,this pipe is soft /split/not connected whatever the problem is this is your source of fumes if your not sure what to do ask a local mechanic to have a look for you
Apr 06, 2017 | Cars & Trucks
Carburetor diagrams b3 323 mazda
Blown head gasket.White smoke is the water getting into the cylinder.
Mar 30, 2014 | Mazda 323 Cars & Trucks
Smelling fumes out the exaust tail pipe
would you please describe the fumes like raw gas fumes oil smell smells rich etc and color of the exhuast fume and if real smokey extra smoke
Sep 14, 2010 | 1993 Buick Roadmaster
I have a ford xe 351v8 it blows lots of black smoke
Black smoke tells me your piston rings are worn. Also the fumes you have explained tells me the valve seals are worn and leaking oil as well
The leaking valve seals and pistion rings will expell the fumes out through the exhaust. If you check your oil level every 50 miles and the oil level is down a half quart or more serious engine wear has occured and needs to be rebuilt soon
Jun 29, 2010 | 1983 Ford Fairmont
Engine fumes leaking into car compartment through the ventilation system - how can I fix this problem ?
The main thing you will need to do is to minimise the amount of 'excessive' engine fumes being generated in your engine compartment which in turn will 'leak' into your car compartment: 1) Degrease your engine and check for leaking oil gaskets especially around the oil refill area: oil leaks at the back of the engine falling on your hot exhaust pipes and on your engine block will generate lots and lots of 'nasty' smelling fumes! 2) Check that your exhaust pipes joints are well sealed especially the one contained within the engine compartment: taking great precautions, check for the obvious leaks from smoke emitted but you could use soapy water to assist. 3) Check that the lining in your engine compartment are in good condition taking particular attention to the 'Firewall' ones (e.g. the one between the engine compartment and the passenger side compartment). 4) Check for broken heating/cooling air hoses leading into the passenger compartment.
Hope it helps!
Mar 24, 2010 | 1992 Porsche 968
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Jan 28, 2008 | Heating & Cooling
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
