The error code 381 on a Konica R2 Large Print device typically indicates a problem with the developer unit. The developer unit is responsible for adding toner to the printed image and when it fails, it can cause the error code to appear and the printer to stop working.
Here are a few steps you can try to troubleshoot the issue:
Check the developer unit for any debris or buildup that may be blocking it. Clean the developer unit with a soft, dry cloth.
Check the developer unit's connector for any damage or debris that may be preventing it from making a proper connection with the printer. Clean the connector with a soft, dry cloth.
Check the developer unit's gears and make sure they are not jammed or damaged.
If the above steps did not resolve the issue, it may be necessary to replace the developer unit.
It's important to note that this is a complex issue and it's best to have a professional technician diagnose and repair the problem to ensure proper and safe operation of your printer. It's also important to check the manual or contact the manufacturer for more detailed instructions or troubleshooting steps, because the code 381 could have a different meaning on different models or brands.
The Konica Minolta R2 Super 700 is a high-speed digital duplicator that uses a pump to supply ink to the print head. The problem you're describing, where the P2 pump makes a loud noise, could be caused by several factors.
Here are a few suggestions for troubleshooting the issue:
Check the ink supply hoses for any kinks or blockages that may be causing the pump to work harder than normal.
Check the P2 pump for any signs of wear or damage, such as a broken or worn impeller.
Check the P2 pump's filter for any blockages and clean if necessary.
Check the P2 pump's voltage and ensure that it is within the correct range.
If the problem persists, it may be necessary to replace the P2 pump.
you check the ink and I know some power cables short out have you tried replaceing the power core and even check if your breaker is of or lose and check see if a switch turns that outlet on and off
the device takes too long to warmup. try switching off then back on when you see the message. if that does not work you will have to call for a technician i'm afraid. good luck
