SOURCE: No Dim's
Skinny, I think your on the right track. Disconnect one of your low beam head lights, turn the headlights on and to low beam, you should have voltage on the "tan"wire at the headlight. If you do not, go to the dimmer switch under the steering column and check the same wire. If it still has no voltage, replace the dimmer switch.
Good luck and let me know.
Regards,
SOURCE: drivers side light is dim,
On the headlight harness to the one that's dim, find the ground wire, and add a new ground to body on that wire.
