Question about Xerox DocuColor 12 Color Copier
Docucolor 12 Problem
It is a docucolor 12. Does the trip switch say 20amp? I see a black switch at the bottom left corner. Yes, this works because I get a reading using my voltage meter going to the boards. Exactly, where is the power supply box? I would like to check to see if it works?
By the way, I would like to know why they work different, if you don't mind. From what I understand, the docucolor 2045 does not have a waste container for the developer is because it has 4 different print cartridge that can be recycled and the docucolor 12 has one. If you use one, then the toner gets mixed and needs to be replaced much more often. Is this right?
Thank you!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
You can find the POWER SUPPLY box at the bottom right corner on the right side of DC12.
Posted on Jan 12, 2009
I'm getting a dirty black line which looks like residue on my prints a quarter of an inch from the bottom from my Xerox DocuColor 12.
Time for a new drum. If it's close to time for a maintenance kit, I'd go ahead and do that, as well.
Jul 07, 2011 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Power problem
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
Dec 27, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
158 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
