Question about InFocus Proxima DP6810 Multimedia Projector
Purple pixels in my DP6810 MM projector
I have reset the defaults to factory specs, replaced the bulb, blow air into it but these purple pixellations just won't go away.
    Scholar:
  • 98 Answers
I have three of these units and all experienced the same problem and repair. I cleaned not only the lcds but all the glass panels and lenses near the lcds. You can power up the unit, select test screen, then carefully unplug and remove the top cover. With it on you can use a q-tip and CAREFULLYA AND DELICATELY clean the lenses and lcd screens. Some of them have a tight clearence so youll need to cut down your q tips to fit in there. It takes be about an hour per projector but i am able to remove the offending dust and FIX the purple splotches. I forget what color it is but its the center mounted lcd that when dirty makes the purple ****. YOU WOULD BE AMAZED AT ALL THE **** THAT GETS STUCK IN THERE!
Posted on Dec 08, 2010
  • 2,237 Answers
You have a bad lcd panel. bad news: you'll have to replace the entire optical engine
Posted on Dec 29, 2009
3M MP8725 - Purple screen image only
the lcd panels are fault,you need a new ones
USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
May 24, 2014 | 3M Office Equipment & Supplies
Patch of purple "scribble" lines on corner of screen
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Aug 01, 2008 | Sony VPL HS10 Multimedia Projector
How to fix a stuck pixel
You can't fix a pixel, it is a display failure and the screen must be replaced.
Feb 06, 2012 | YOBO FC-16 Go Portable SNES System
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Takes a while to start up and turn on. Sometimes purple pixels
you have a power supply problem, look for bad capacitors normally they are flat on the top, but when they go bad they get like a bubble on top. just replaced them. good luck
Jul 10, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
My proxima dp6155 projector after any time looks with a vertical purple line in the right side, whats the problem
reset the settings to factory default. there may be a resolution issue. make sure it matches the source. if the line is straight and goes right along the pixel line, you may have an lcd issue. if it's blurred, it could be a bad polarizer.
Dec 16, 2009 | InFocus Office Equipment & Supplies
Got a purple stripe from the lower edge of the screen center to center. gradient to the middle of screen. like 100 lines wide. any hints THANKS michi m
if it's sharp edged and inline with the pixels, you have a bad green lcd panel. if it's fuzzy and random, you have a burnt light filter. either way, it's an optical engine issue. you can try to go into the case, remove the ribbon cable for the green lcd (unlock the ribbon clip first) and reinsert it and lock it down. if that doesn't work, you'll have to replace it.
Dec 02, 2009 | Sanyo PLC-XP51 Multimedia Projector
I am getting a red spot on my screen. Is this a
no, it is the light filter (polarizer). it is caused by excessive heat and dust buildup. blow out projector with canned air to prevent further discoloration, but the filter needs replacing.
Aug 04, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
After 20 minutes of use picture shuts down. (Sharp XR-10X)
use canned air and blow every bit of dust out of every vent and hole. if you want to, you can remove the top (6 screws on the bottom, and the 2 top screws on the back) and blow dust out that way. i could also be a power supply problem. from excessive heat, the capacitors on the ps dry up and don't work as they should, causing shutdown.
May 24, 2009 | Sharp XR-10X Multimedia Projector
InFocus Proxima DP6810 Multimedia Projector Logo
415 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
lekmai
lekmai
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
