Question about Toshiba 32AFX61 32" TV
I have a Toshiba 32A42A 36inch tv, it is 5 years old, all of a sudden the red light by the power button keeps blinking and it won't turn on at all
snakehead
  • 1070 Answers
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
Posted on May 02, 2007
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
My toshiba 32a42a power button is broken. Most remotes require the tv to be on so you can program it. How can i turn it on.
Contact the authorised service center for Toshoba to get a knob for ON'OFF switch to your TV. It is very easy to fix it.
May 06, 2012 | Toshiba 32AF42 32" TV
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
My toshiba 32a42a does not have a power button-how do you turn it on or off?Most remotes require the tv to be on so you can program it.
This set has a power button on the far right of all the buttons on the front. I looked at page 11 of the owners manual http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001840.pdf and it shows it very clearly. It looks as if the power button may be turned the opposite way from the other buttons. Thanks
Oct 29, 2009 | Toshiba 32AF42 32" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
May 02, 2007 | Toshiba 27AF41 27" TV
Toshiba 32AFX61 32" TV Logo
336 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
