Question about Whirlpool LSR6334LQ Top Load Washer
Whirlpool LSR6333LQ0 my washer will not fill up when i i turn knob to start a load (the washer hums). But, when i turn the knob to the rinse cycle the washer is fine. How can i get the washer to recognize the entire cycle?
    President:
  • 878 Answers
Ch, first thing you want to do is check the hose going to the hot side of the inlet valve. There is a screen on the inlet valve that could be plugged with gunk,grit or sand. Remove the hose and clean it out. The humming you hear is the valve energizing. Something is preventing the water to come through. The rinse is usually cold water so that is why Im suspecting the hot side is plugged. Check this first and if that doesn't fix it, it may be the valve itself...Catriver..post back.
Posted on Apr 27, 2007
    Novelist:
  • 114 Answers
ALWAYS CHECK HAVE SOMEONE WHO KNOWS ELECTRICAL APPLIANCES CHECK YOUR APPLIANCES. ALWAYS CHECK "WASHER DOOR SAFTEY SWITCH" IT COST UNDER $20 Joe_Rex
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't fill on wash cycle, but will fill if I turn knob to rinse cycle. Machine will spin and agitate if I turn to appropriate spots, but no water will come in when it should to wash.I hear a humming...
water inlet valve sounds like it's bad and you can check the screen where the water lines hook up to the washer. those screens sometimes get so corroded the water won't get passed
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
193 people viewed this question
Sal De
Marvin
Marvin
jimorris77
