Question about Alpine MRD-M1005 Car Audio Amplifier
Amp powers on, no sound from subs
Ive had this alpine mrd m1005 for about a year and a half. it is worked the entire time up until about 2 weeks ago. the sound cut out, so i figured the power or ground was messed up. the amp actually works though. all the normal lights come on it, letting you know theres power to it. however there is no sound coming from my subs. i checked the speaker wires from the amp to the subs and even replaced them. i scanned the rca cable and it appears fine; the turn on lead is in between them and that works fine so i assume the rcas are good. what else can i check? thanks.
  • reggin182 Dec 29, 2008
    my amp isnt in protect mode though. it has the normal sign of "14.4v", showing the voltage. if it goes into protect it puts up different signs. since its acting normal, could this mean that something else could be the problem? or can a blown output still allow the amp to function correctly? if so, which piece would i need fixed? i have an electronics guy that repairs things well so i would like to know what kind of price im looking at. this was a $350 amp afterall. thanks again.
  • Cory Wichman
    Cory Wichman Nov 07, 2014
    That's not necessarily the case (the amp being blown), though it is a likely possibility. You need to check voltage levels with a multimeter and also visually inspect the ground connection. Sometimes remote and ground alone can illuminate the power LED, even though there is no voltage at the power wire. Also, the head unit's RCA outputs could have failed, or the RCA cables could have come unplugged. You need to inspect the wire from beginning to end and ensure it's plugged in at both ends. Finally, the amp could be working just fine yet not producing any sound if the speaker wires aren't properly connected. There are speaker wires running from the amp to the speaker box. Both sides need to be inspected. With a multimeter you can test ohm load at the amplifier. Also make sure the connections inside of the box are sound. (If ohm load is present at the amplifier, then the connections are good). That's about it...
  • 15,935 Answers
The output is blown. It is in need of service.
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause.
Posted on Dec 29, 2008
Amp is getting power but im not getting sound from my subs, could I have fried the rca jack?
Yes double check ur wireing you can fry port or wire from putting output to output try a different set of rca s if not working probably fried port in amp
Dec 17, 2012 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
There is a smell in my car every time I play my system for long periods of time. Its a burning smell. Everything is wired correctly and I have a separate battery in the back of my car to power my subs. I...
The problem could either be the amp over-heating or the subs could be over-heating as well. One of my friends owns an Alpine MRD-M1005, and one day they decided to clean it inside and out and realized they had some burnt spots on the circuit board, although they never smelt anything burning, and the amp still works fine.... As for the lights dimming you should probably buy a power Capacitor, atleast a 1 Farad or larger.
Hope this helps.
Nov 08, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Jan 19, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
When I hook my JL W7 sub to my alpine mrd m1005 amp the sub is pushed out and stays that way
Hello christensen7,
It sounds like there's DC current on the amp output terminals. Disconnect the sub and test the output with a multimeter. If there's DC there, most likely the amp is shorted internally and needs repair.
Hope this helps.
Aug 17, 2009 | Alpine MRD-M1005 Car Audio Amplifier
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Help!!!!
I would say any decent pair of 12" or 15" (single 4 ohm voice coil) subs that can handle at least 500W rms would work. The rest is going to be based on cost, type of box, type of music, etc.
Feb 20, 2008 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Alpine MRD-M1005 Car Audio Amplifier Logo
373 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
