Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
Magnavox 437S 52 " Flat Screen HD TV....Have had no problems since purchasing in June 2008. Had sudden change in color spectrum to mostly green, yellow and blue with no red. TV is not responsive to any attempt to use the color adjustments through the menu have tried all...adjusting color, tint, color temperture etc. white balance point for all....Nothing makes any difference. I am not a novice in making these type of adjustments. Help
    Genius:
  • 2,920 Answers
It should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Posted on Dec 28, 2008
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
Maganavox rear projection tv has developed double vision
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
60 inch maganavox rear projection tv blue color almost gone if it is a bulb where can I buy one
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Maganavox 51mp392h/17 double objects at top and bottom of screen.
You need to replace your convergene ICs. It's best to call a repairman for this job.
Aug 09, 2009 | Philips Televison & Video
Can you replace the picture tube on a big screen maganavox tv?
yes it can be replaced.but the tubes are costly to get replaced.you can get the parts at www.partstore.com or at www.shopjimmy.com thanks.
Jul 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Display problem for magnavox 42" model 42mf230a/37
first make sure its not an input problem or from an external source.Disconnect all inputs and see if lines are present with no inputs to tv.if lines affect menu and or ON SCREEN DISPAY (top) there is a good chance (SSB) board could be bad .I would start with this board first ,lvds cable (second) and last the logic board (comes only with new LCD)
Jun 23, 2008 | Televison & Video
Green verticle line on Maganavox flat screen tv
Most likely it's due to the LCD panel assy failure. It may cost you as much as to buy a new tv. The LCD panel is very expensive in retail market.
Jan 24, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
264 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
