Question about Radio Shack VGA PC Camera Webcam
Cant hear sound on recorded tape - Radio Shack VGA PC Camera Webcam
  • Anonymous Feb 23, 2009
    I have a similar problem, although I can hear some of my recording, most of it gets cut off
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 23, 2009
I recorded a cd from a cassette tape. The tape sounds good but the recorded cd has much static
I would need to hear how it sounds first hand, it may be a copy guard that is causing this.
Jan 10, 2017 | The Audio Players & Recorders
My Tascam Porta 02 records but I cant hear any playback ! What to do to fix ?
Check its headphone out for any sound. Check the cables going to the amplifier. Try another tape for the playback sound.
Sep 23, 2014 | Audio Players & Recorders
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
I cant get this product to record a video and view whats been recorded? When i try to record it tells me to(check tape's erase protection tabe.)m
It sounds like you are talking about a VHS tape look at the lower left corner of the tape as you are putting it into the vcr there should be a small square hole there with the tab broken off put a piece of scotch tape over this hole it will than let you record on the tape again
Mar 20, 2011 | Video Game Consoles & Games
Most decks have a headphone socket. But if you can't hear anything on playback via that it probably won't record via tape to tape. If a fault it is clearly connected to both channels, so look for something common to both channels. IE: a switch or an IC.
Feb 16, 2011 | Sony Audio Players & Recorders
Cant get program to work
to eliminate the 20 seconds issue, uncheck the auto stop box...this was causing me problems and has been resolved since the box was unchecked.
May 30, 2009 | Xitel INport Deluxe for PC
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
Radio Shack VGA PC Camera Webcam Logo
24 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
