Question about Sony Cyber-Shot DSC-P32 Digital Camera
My sony cybershot 3.2 won't turn on when i want to take pictures but it turns on when i want to view the memory of the set up.
This is usually due to a stuck shutter cover. First off though try hitting the camera reset button to see if this solves it. If not carefully open camera by removing screws, disconnect ribbons, unhook shutter cover motor wire (2 wire connector) pull board out and away from front housing, force cover open or see if gears or jammed, camera will work if cover is left open but you will have to live without it. Once forced open leave motor dissconnected, or if you found gears were jammed reconnect it. Be very careful of flash capacitor circuit and contacts, they may shock you if you touch them. Hope you get it working if you still have the camera.
Posted on Mar 11, 2009
My camera will turn on, then when screen is on for about 5 seconds, the screen turns off, and the red light beside the SIM card slot starts flashing.
Take out memory card form camera and turn it On, if camera stays On and shows normal view that means memory card is bad and causing problem.
Put new memory card in camera and take pictures.
Thanks.
Nov 04, 2010 | Sony Cybershot DSCW370 Digital Camera
Sony cybershot dsc-w130 keeps showing "reinsert the memory stick" when i try to take a pcture or adjust telephoto when i do it does not make any difference
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 06, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My sony cybershot dsc-h3
Symptom shows your DSC-H3 has problem in Lens Mechanism and you need to replace complete lens.
If you want to replace it by yourself, Its part number is as follows...
A-1359-213-A LENS BLOCK ASSY
It is available in Parts Store on $150
Or contact nearest Sony Service Center for replacement.
Oct 12, 2008 | Sony Cybershot DSC-H3 Digital Camera
Turn Power on/off - Can only view pictures
this model has been recalled - contact sony fort repair/replacemtn
Oct 10, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cybershot DSC-P200 problem
I had the same problem with my camera a year ago I send it in to sony & they fixed it,for $20.00...
Jun 10, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Sony cybershot dsc S650
To salvage the pictures you could just use a memory card reader. As for the camera itself I cannot say, but by your description it doesn't sound promising.
Feb 04, 2008 | Sony Cybershot S650 Digital Camera
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
