Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Light in ref off / no power to main box with cooling level.
Inside the main ref compartment there is a box which shows two green numbers (showing cool level for freezer/ref) It appears there is no power as both digital numbers are black and the main light bulb in the ref doesnt work either. I pulled the bulb out and checked it in another light and it works???
It seems to still be cooling but I just noticed the problem a few hours a go. It also makes a rattle noise when I open the door? Any of you professionals out there have any ideas for me?
Whirlpool Gold (approx 3 yr old) GD5RHAXNB00
  • guitarblu Mar 04, 2009
    2004 model GD5RHAXnB00 S/N SR4639192\r\n
    Ref not cold enough, turned up, won't freeze ice.
    Was moved, stood up for 30 hrs before plugging in.
    Light not on, switch and bulb replaced. Also, indicator LED's not eluminated.
    Thank you
    Problem Solver:
  • 5 Answers
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Posted on Dec 31, 2008
  • 318 Answers
This unit has a problem with the control board that causes the display to go out and have no power to the interior light. when it fails, it will go into a default function and will operate at the factory settings. it is not good, but it will continue to work this way forever.
with this unit being 3 years old, its not likely that whirlpool will do anything about the repairs, but you can call their 800 # and ask if they will help with the repairs. sometimes they will give an authorization for repairs, maybe parts, maybe labor, or both.
it might be worth a cal to them to see, but dont hold your breathe. good luck with whirlpool and if they do give you an auth# then they will recommend an authorized company to do the repairs.
Posted on Dec 28, 2008
Ref has quit running/cooling. Lights inside are on, the lights on the temp controlls are off. Any isea?
I ran into this problem last year on the same or similar model.
if there is no cooling or fans or compressor running ,but lights are on in both compartments,and no control numbers are on the electronic control mounted to the left of the compressor is the cause of the
problem. It is expensive but rebuilts are available on Ebay .Ive
used national rebuilder parts many times,with excelent results.
Apr 30, 2014 | KitchenAid Superba Architect KSCS25INSS...
The fridge turned off today due to a power outage and now it only shows a green bar on the display and is not cooling!
What kind of refrigerator, and whats the model number? Green bar flashing I'm going to guess a Samsung. If so, then hold down two buttons at the same time on the display, It depends on the model number as to which two, but in most cases its the power freeze and ref buttons. If you can get the brand and model # to me I could describe more for you.
Mar 22, 2011 | Refrigerators
Radiator cooling fan fuse location for Ford Taurus
The cooling fan on a ford car usually does not have a fuse. The cooling fans are controlled by a relay in the power distribution box inside the engine compartment. The box is usually located near the battery. Your owners manual should have a guide showing you what each relay in the box is for.
Jun 29, 2009 | 2001 Ford Taurus
Refrigerator is not cooling
I need you to check a few things with the refrigerator unplugged. When ready, Let me know.
Jun 19, 2009 | KitchenAid KSRG25FKSS Side by Side...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
GE Side By Side Stopped Working
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Jun 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section.
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
215 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
