Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher will not drain
After a cycle the dishwasher had water remaining in the bottom of the machine. Even when I drain it there is still about 2 inches in the bottom.
Please help
  • 8 more comments
  • ctbf2424 Dec 28, 2008
    will not drain after a cycle
  • prezdave40 Dec 29, 2008
    Still have about 2 inches of water left in the bottom. It will not drain.
  • eochoa97 Feb 15, 2009
    Same problem. If I start another cycle with the water still at the bottom, it seems to be draining some water because it will not leak out, but at the end of the cycle there is water at the bottom.
  • tgriffin25 Mar 02, 2009
    Cleans dishes but some water always remains on the bottom. I cannot find any solutions on this site?
  • Anonymous Mar 04, 2009
    Same problem but I don't hear any solutions out there.
  • Anonymous Mar 06, 2009
    like everyone else, it leaves two inches or so of water in the tub after the cycle. I don't think the screen is clogged. I took the inside apart and it felt and looked ok.
  • bremco125 Mar 11, 2009
    The dishwasher has water 2 inches of water remaining in the bottom of the unit after a complete cycle. Also the dishes appear as though dirty water has been used during the rince cycle. I have taken the unit apart several times and the screen is clean and no other debris is in the remaining water... I see lots of complaints but no solutions...Bosch is my next option... so much for buying domestic....
  • Thomas Kautz Mar 18, 2009
    water in the bottom of the dishwasher
  • jbozarth Mar 22, 2009
    dishwasher does not drain completely
  • Rajan108 Apr 06, 2009
    Dishwasher will not drain. There is water remaining in the tub after the whole cycle has ended. Please let me know how to fix this. Thanks.
I have had that probem and the issue is food idems the size of beans or peas make it through the filter system and plug up the drain. Take out both the round and flat filter. The water drains through a row of ridges. Take a probe (fork, toothpick, ...) and clean out between those ridges. I can almost guarentee you will be pulling stuff out. It isn't necessarily visable, you have to probe down the drain a little ways. Let me know if this works.
Posted on Apr 04, 2009
What is the solution to dw not draining
Posted on Jan 03, 2009
Dishwasher wont drain
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
My Kenmore elite dishwasher 665.13793K600 has 2 problems: 1. won't drain water 2. won't even start working today Please help!
I have a Kenmore model # 665.13793K600 and it has been having a small puddle of water remaining in the bottom at the end of each cycle. I've taken it apart and cleaned it. I'm thinking I may have the drain hose incorrectly positioned or it could even be something unrelated. I can only think of the drain because I replaced the kitchen faucets a coupe of months ago and it could be since then that this has been happening.
Sep 09, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
236 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
