Kenmore washer will not drain after wash cycle
It just stops after the wash cycle and won't do anything else. If I manually move it to the rinse cycle it will then start agitating again as if it had clean rinse water in there....then, it will drain and spin as usual. I just used the second rinse cycle to make sure it was rinsed. What could be causing this???
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
