Propane heater cuts on and off.
Someone said it could be a part needs to be changed out because it was made for a natural gas heater.
  • 61 Answers
Running propane through a gas heater is dangerous and will ruin the heater!
Posted on Jan 02, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I have 3 natural gas fire places. i would like to know if i can change it to propane. i'm thinking i would just have to change the logs and hook a tank up outside. can some tell me if this would work.
Typically gas log sets are factory made for either natural gas or propane. If you want to use them on propane you need to find out if a LP conversion kit is available for your brand/model #. Ask the place where you bought them or ask the company that installed them (if you didn't put them in yourself). If they can be changed over to propane, then you will need to buy the propane tanks, regulator and gasline or just have your local propane company put in a pair of 100# cylinders for each fireplace (or 420# cylinder to service all 3 fireplaces) with an auto-switchover regulator. They can also do the conversion, if the conversion kits are available. Let me now if you have any other questions. Douglas
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane...
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Oct 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Oct 08, 2009 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Want to change Dayton 3E133E from natural gas to Propane
Would have to have conversion kit IF available. Must get from mfr. The Dayton brand is owned exclusively by W.W.Grainger. Not sure if someone else makes their furnaces for them. Start w/ Grainger, if they won't sell to you maybe they will give you the name of a company who will work on it. Good Luck!
Mar 09, 2009 | Dayton Electric Heater
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
