Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer has lost all power
The printer has lost power. I have checked the cable connections and the household fuse box-also tried to plug it into several outlets. Can't find our manual.
  • Anonymous Mar 12, 2009
    This happened to our printer awhile ago. We ended up moving it to a different room, turned it off and plugged it in. A few days later it turned on and has been working ever since.
  • 326 Answers
Its the problem of ur printer powersupply and not ur fuse box needs repair on power supply board of ur printer.
Posted on Dec 28, 2008
Canon iPf6350 lost all power when changing an ink cartridge
take off the ink cart. from the printer clean the contact points and power ON .watch for any movement of carriage assy.
If not take a series lamp(incandescent bulb) of 25W/220v connect the printer check the bulb for glowing slowly to bright and bright to dim (regular interval)
If the bulb glows a while there may be something wrong and may need assistance of trained engineer.
Feb 05, 2015 | Canon imagePROGRAF iPF6350 Inkjet Large...
Just printer a couple of documents..Printer lost power and will not print anything,,Unplugge and repluggd into a working plug,,,Nothing,,
Double-check that the power cable is plugged tightly into the back of the printer, as well; also check the power cable for any cuts or fraying. If the cord looks okay, and the printer will not power on at all, it is very likely that the power supply inside the printer has failed. You will need to either return the printer (if you are within 30-90 days, depending on your place of purchase), or contact Canon for warranty service. This is not a part I would attempt to replace yourself, as it involves soldering connections.
Dec 22, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer X5270 has lost connection. In the properties field of the printer, under the General tab the location field is blank and under the Ports tab a check is placed by the USB...Virtual port for USB....
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X5270 All-In-One InkJet Printer
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer light is on but i cant print anything?Help
If you are connected via the USB cable, the connection may be lost (or the setup which is particular to the actual USB plug itself). Try deleting the printer and reinstalling it. Don't change USB ports after the printer is installed by the way. Also we had problems with this when the printer was networked (shared) and the auto sense was on - after another person printed the local box would seize up. Try not having the printer auto sense its presence so that 2 printers show up in the network neighbourhood. Of course check that the cables are installed right and try changing USB ports.
Jan 31, 2010 | Brother HL-2040 Laser Printer
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Lost power to printer after cleaning mirrors in optical box
Check the following.
Power switch on the back of mqchine ON.
Power cord firmly in place at both ends.
If there is a fuse or circuit breaker next to the power in connection, confirm it is good or reset.
All covers properly closed.
All internal units in correct position.
Hope this is of some help.
May 19, 2009 | HP Color LaserJet 2600n Printer
HP printer
Try to unplug then plug in the power cords if not working im sure your current supply will be lost. due to the current supply in your area or lost connection of your power supply.
Jun 05, 2008 | HP LaserJet 3030 All-In-One Printer
Re-installation of printer software won't complete
i'd say you may have a corrupted system file..had your computer tuned up lately?
Mar 28, 2008 | HP LaserJet 1020 Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
244 people viewed this question
old marine
old marine
