Question about Philips SA3025/37 Flash MP3 Player
When i turn the player on a lock pops up an it turns off
On the side there is a switch tun it down because you have it on lock
Posted on Dec 31, 2008
My dvd locked in the sony slvd 360p dvd player. how do i eject the dvd from the dvd player?
Open the door to the DVD.. You will see a white plastic wheel inside with "teeth"- like a gear. Use something small to turn the wheel to the right. When it feels like it won't go any further give it a little extra turn and the drawer should pop open. Make sure you are turning it to the right (clockwise)
Oct 29, 2010 | Sony SLV-D360P DVD Player/VCR
Lock on mp4
Check the lock switch on the player. It's meant to prevent the buttons from being pressed while playing. If that doesn't work, contact the manufacturer.
Dec 07, 2009 | Philips GOGEAR SA6045 MP3 Player
Mp3 won't turn on
Make sure the hold/lock switch wasn't accidentally engaged, then try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips GoGear HDD6330 MP3 Player
It wont turn on!
Make sure the gold/lock is not engaged.
-Tha Mp3 Doctor
Jan 22, 2009 | Philips GoGear HDD1830 MP3 Player
Mp3 player comes on then says "flash error! please back up the data and format the player"
HOLD THE POWER BUTTON AND THE LOCK BUTTON WITH PLAY BUTTON AND THE RIGHT BUTTON ON THE MP3PLAYER
Nov 04, 2008 | iLO (2 GB) MP3 Player
Head unit is Locked
Turn it of, when u start the player again. Make sure u make the dvd sreen pop ut at the same time you start the player. Then the keypad should appeare.
Worked for me
Aug 15, 2008 | Dual Electronics XDVD8183 Car DVD Player
Entering recovery mode is not possible
Disengage the lock switch, then try this: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 03, 2008 | SanDisk Sansa e270 MP3 Player
Won't Turn On
Make sure hold/lock not enagged
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 23, 2008 | SanDisk Sansa m240 MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Locked up sansa
Apr 18, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
