Question about Uniden Voyager 2-Way Radio
Transmits by itself
When left on by itself it recievers okay then will start transmitting by itself. I have had the ppt board out no sign of any water damage. Is okay when ex mic/speaker plugged in. Note Marine VHF used in and around salt water. Thanks for any help Wayne
  • Wayne Middleton Apr 26, 2007
    I do not think this unit has a VOX feature the ptt button is working fine i have removed it from thr pcb and checked it.
    Thanks for your reply.
    Wayne
  • 123 Answers
Check if the VOX features is turned on, check if the Ptt button has the "normal" bouncing or clicking.
Posted on Apr 26, 2007
My cobra 25 transmits but doesnt recieve. I changed all finals but it still will not recieve. Any ideas on what i need to do
finals have nothing to do with rcv.
u need to trouble shoot the receiver.
start at the t/r switch and make sure the antenna is connected to the front end of the rcvr when xmit is not active.
if u hear absolutely nothing u may have an audio issue. try a headset and work backwards.
Dec 25, 2014 | Radio Communications
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
I have no recieve transmits fine it was working then i seen a flash and no recieve
Try other mics what happen to me was the wire came lose and hit pin 6 which is power pin it may just have burnt the wire in mic plug
Dec 02, 2012 | Magnum 257 CB Radio
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
My HCB 10 transmits a carrier but has no audio. Reciever is fine. Where do I get a schematic?
hello there ,a very simple solution to this problem remove rear covering and circuit board you will notice the mic anylise it for wire breakage or dry solder joint iff you have a replacement mic you can replace it ,if this fails its more than likely your audio chip has given up ,its best to leave it to someone with expertise goodluck ei5glb
Dec 29, 2010 | Maxon HCB-10C CB Radio
My kx-145 king aircraft radio recieves but transmits pourly can i have that repaired
transmits pourly can i have that repaired Holt, Searched this quite a bit, it looks like the transmitter is none adjustable.Check the attached Bendix link and use there support or contact page, they also have a trade up page,,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Home BendixKing by Honeywell
Dec 08, 2010 | Kyocera KX 440 Cellular Phone
Cb radio
Some CB Radios require the mic works right or the receive won't work. Also it could be a detector diode bad. I have also found cold solder joints ( broken lead from the PC Board ) around the if sections. You might take alook with a magnifing glass and see if you can see any bad joints. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 02, 2007 | Galaxy Radios DX-33HML 40-Channels Base CB...
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Uniden Voyager 2-Way Radio Logo
100 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
