Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Hi, My name is Titus with Microsoft. Customer installed the Acer Lcd monitor update and since then the computer is in a reboot loop. He has xp on his machine
  • chennai_titu Mar 07, 2009
    Hi I am a tech rep for xp. I have tried these basic things but did not help. I suspect it to be a hardware issue.
  • Acer Master
  • 13,433 Answers
You are with microsoft?
Start the computer in safe mode and uninstall the software.
are you MCSE?
Posted on Dec 28, 2008
  • Ekse Mar 07, 2009
    Reinstall windows and see if it helps, use repair installation so files are not lost like pictures and documents, make sure you don't format.
Network Adapters
No. It is a Microsoft program. An update is probably a better description. You should look at the Windows Update website for updates while they are still available for XP.
May 21, 2013 | Computers & Internet
Driver acer P191W LCD Monitor windows 7
Sounds like driver related problem to me... use this software to update all of them: Driver Update Software for XP Vista 7 8 (especially monitor driver)
Brian
Jun 20, 2012 | Acer LCD Monitor P191W
Downloaded Windows XP Update SP 3. Now system
When you installed SP3 it was also placed into Add/Remove programs, (In control panel). Boot the system and enter safe mode. Uninstall SP3.
See also Microsofts instructions on how to remove SP3; http://support.microsoft.com/kb/950249
Did you find this helpful
Mike
May 21, 2010 | Microsoft Windows XP Home Edition
Low screen resolution with new Windows 7
Right click on the Desktop, select Personalize, then select Resolution, then adjust it according to your monitor's specifications.
Dec 29, 2009 | Acer X193W LCD Monitor
During install of Vista Service Pack 2, Dell laptop gets to Installing 3 of 3 27% complete then reboots. Gets to same point and reboots again. Seems to be stuck in loop. What to do?
Do not install again allow your computer define the update for the Vista Service Pack 2 online. This would be better option for you.
Kind Regards
Nov 09, 2009 | Microsoft Computers & Internet
22" SOYO LCD widescreen monitor problem!
Try seting your dettings to 1024X768 and see if that solves your problem.
Sep 15, 2009 | Planar PT1503NT 15 in. Flat Panel LCD...
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
