Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Toilet not flushing properly
Jacuzzi BK 37 elongated 1.6 gal flush.. water just swirls around and nothing gets down the drain.. flapper opens all the way and the out flow of water from the tank is slow... in fact if the flapper is up the tank will fill faster than the water goes out.... no apparent problem in the trap itself and nothing appears to be blocking the flow of water out of the tank ???
  • Anonymous Jan 07, 2009
    Response to Joe Lorna: The toilet is only a year old. And the problem seems to have suddenly appeared. Plunging doesn't help. The water goes down, but then with the next flush, its back to the same swirling, etc.
  • Joe Neff May 11, 2010
    How old is this toilet? Did the problem suddenly appear or did it start gradually and get worse? Does it help when you plunge it? Let me have more info and I can help you.......Joe
    Sergeant:
    Champion:
  • 239 Answers
There are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Posted on Jan 04, 2009
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
How to drain the water out of a perfecta jacuzzi toilet to replace flapper
shut off water supply. flush toilet. There will be a little left .You can vac out with shopvac if you must.
Jul 14, 2014 | Jacuzzi Bath Perfecta EZ33 959 White round...
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
The toilet does'nt have the same flush pull taking a couple of flushes very slow draining
Check the following: Is the water level in the tank properly set? Is the flapper valve opening fully when flushed? And is there any blockage in the waste line? Use a plunger to try and clear the line if the first two items are OK.
Apr 24, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Dec 12, 2009 | American Standard 2002.014 - Champion4...
My one piece elongated bowl toilets are filling for no apparent reason between flushes what can I do to fix the problem
it sounds like your flapper (flush valve) is leaking.
if you here your toilet filling up and no one flushed.
push down on flapper to see if you here the water stop leaking out. if so replace flapper. even if toilet is 1yr or less old. could be a bad flapper. hope this helps. duane :)
Oct 11, 2009 | American Standard 2002.014 - Champion4...
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
1,855 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
