Question about Hobart N50 Stand Mixer
More info re: n50 hobart mixer
I don't own a mixer, but reading about Kitchenaid mixers have me a little leery, since Kitchenaid was sold off to Whirlpool. I believe Hobart was the original maker of Kitchenaid products?? I've read that the newer Kitchenaid mixers have been using plastic gear housing in their highest end mixers and there have been problems. Now, my question. Do Hobart mixers use all metal parts in their mixers....not scrimping on quality by replacing some parts by using plastic? Is the N50 mixer made in the USA? In your opinion, are Hobart mixers worth the high cost, are they truly the best? Thanks for your help. Also, what is the wattage of power output? Judy
  • youngest0ne Jan 01, 2009
    Thank you for your help!
  • 135 Answers
Judy. Hobart was sold to Illinois Tool Works (ITW) several years ago. The Kitchenaid product line was sold to Whirlpool Corp. several years ago too.
The new N-50 mixers have a motor that is designed by Hobart, but no longer built by Hobart. Last year Hobart began out-sourcing approx. 12-15% of their componnents to Asia. Their parts catalog does not show anything but metal gears. I suspect the new motors have been built in Asia. Wattage is not the output of the motor, but how much power it takes to run the motor and is no indication of how much power goes into your mixing bowl. The true measure of mixing power is horsepower. The N-50 motors are rated at 1/6 HP. Wattage claims by mixer manufacturers is a complete snowjob, and they all do it. Consumers have no protection as a result of this policy. It is a marketing ploy to make you believe that this indicates output power. Shame on all of them! Most componnents of the new N-50's are still manufactured in the USA.
I see that you've done some homework on Kitchenaid Mixers. I wish I had before I bought mine. Yes, they have a plastic transmission housing, and yes, they fail under strong loads demanded by bread dough and stiff cookie dough mixtures (my HD Professional 450 watts failed 5 months out of warranty, after only 30 uses making bread). Go to the www.consumeraffairs.com website and search for Kitchenaid mixer problems and reviews and brace yourself for a shock.
My mixer failed on Oct. 28th. and I had to fight tooth and nail with Kitchenaid to get them to re-imburse me for the cost of the parts that were destroyed by the housing failure. Here we are in 2009 and I'm still waiting for one more part. Kitchenaid parts take at least a month to arrive (in my experience).
I didn't do the research on mixers until mine failed. Since then I've purchased an older Hobart N-50 (with a motor BUILT by Hobart), and this is what I recommend you do, as it will save you much grief down the road. Mine was manufactured in 1990 and only needed. re-greasing to make it like new.
You can find them often on eBay but will have to buy without trying them. Try to find one that is newer rather than older, as a rebuild will get very expensive. I got mine from a Rest. Equip. Wholesaler and was able to try it out in all gears. The previous post (solution) was correct in saying that you should look for one that has a black knob on the shifter handle, this will be a newer one as opposed to an ancient one with an all metal shift lever and potentially worn out innards. If you find one, take it to Hobart, or a Hobart tech can come to you (check service rate) have the unit cleaned, inspected and re-greased. Sit back and take comfort in the fact that these mixers were built like a tank, and will probably outlast you.
Most of all. Good luck, and happy hunting. ricardok45
Posted on Jan 05, 2009
  • 49 Answers
N-50 have very good motors the do have one non metal gear its made out of fiber. its the main gear that drives all 3 gears. are they woth 2,000.00 No way. you can get a used one on Ebay for far less. look for one with a round black ball on the shift handle not the all metal this will be one thats not the oldest as the oldest can be a big risk. and parts are more availble on the changes over the years such as the on/off switch look for a toggle switch not a plastic what looks like a wall light switch.
Posted on Dec 29, 2008
  • 4 Answers
Kitchenaid stand mixers did have plastic gear housings in the past, but Kitchenaid discontinued that in early 2007. Kitchenaid's Pro line has had all steel gears and transmission housing for the past few years.
Posted on Jul 10, 2009
Mixer wont start
Are you still having an issue with your HOBART N50. Let me know and I can walk you through it.
Oct 21, 2013 | Hobart N50 Stand Mixer
We need to buy some parts for Mixer N50, Please provide us part list easy to order from you.
www.hobartservice.com click on locate an office, enter your zip and it will show the office closest to you. They will be happy to sell you parts for any Hobart product.
Jul 01, 2010 | Hobart N50 Stand Mixer
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
May need lubrication out of use 15 years
Hi Snowbird. Your mixer was manufactured in late 1940's or early 50's. It was sold with one all-purpose combination whisk/beater. There is no dough hook available from Kitchenaid. There are two greases you can use in your mixer. Shell Darina-2, or Chevron FM ALC EP-2, the Chevron product is rated as "food grade", meaning that it is safe to ingest if it drips into the food you are mixing.
Remove screws and cover to expose the transmission. Remove all traces of old grease and replace it with one of the above "approved" greases. If you find this solution helpful, please rate it. ricardok45
Feb 04, 2009 | Hobart N50 Stand Mixer
HOBART 60 QT MIXER MAKES STRANGE SOUND
could be your contactor bad chattering and it will make a hum to for a spit second
Jan 16, 2009 | Hobart N50 Stand Mixer
Looking for older Hobart logo for N50 mixer 1965
you would have to have it made not available
Jan 03, 2009 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Hobart N50 repair books
parts books are available at hobartservice.com for free and you might be able to find service manuals on ebay
Oct 22, 2008 | Hobart N50 Stand Mixer
Hobart N50
Some of the N50's were packed with a white grease. It tends to seperate. So the oil portion finds it's way out. It sounds like it is getting into the motor case, and is running down the inside of the column. Hobart now uses a brown clay based grease --- Darina 2.
If the amounts are small, and the mixer is not excessively noisy, I wouldn't be concerned. If you wanted to fix it, the transmission would need to be removed, cleaned, and repacked. For a Hobart tech, 3 hours labor, $45 grease, plus parts.
Jun 19, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
687 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
