Question about Teac PD-H500 CD Player
Teac DV-H550 DVD connection to reference 500 series
Hi I wonder if anyone knows what's going on here ? I recently purchased the afore mentioned DV-H550 DVD and placed it on top of my reference 500 series system. I play it on my TV via the scart and the audio through the TV is fine too. I connected the remote lead to the spare remote socket on the back of the AG500H receiver but the system does not switch on through this. Oh well ! But I checked the CD output of the DVD payer through the amp and it is fine. Only problem now is that if I insert a CD into the existing 500 CD player or the 550 DVD player they both display the last track first. Not track 1 as previously ! I have to press play to get them to start on track 1. A minor annoyance I know but has some memory chip got switched on and if so and is the system easy to reset ? Do you do this through the reset hole at the back of the receiver ? Hope you can help from a disgruntled physicist
Benimur
  • 6966 Answers
SOURCE: TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
SOURCE: Teac A-H300 Amplifier
I found the problem....one thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Posted on Oct 20, 2008
jack_daniels
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
I wish to connect a Teac DV-2170 DVD Player to an LG Television. LCD TV Model 42LE5310. I do not have the DVD Manual, do have a 3 cable, red, yellow, white connector. What else do I need and how do I...
Dear allanjj ,
please click this link to get you Teac DV-2170 DVD manual.
http://ernie.awa.com.au/ArticleDocuments/2246/TEAC%20DV-2170%20Instruction%20Manual.pdf.aspx
please read this manual to clear all your doubts
Thanks
Jun 19, 2011 | Teac Esoteric DV-50 S DVI Model In Stock
Tip
Teac DV-L800 DVD remote control problems
My remote control did not function at all. I flipped the switch in the back of the DVD player from "system" to "single" and not the remote control works fine. This is not mentioned in the manual.
on Aug 10, 2008 | Teac DV-L800 DVD Player
Does anyone know how to de-code or hack a TEAC DV-H500 cd/dvd player. After owning for several years i still can't play or watch many disc's. Many Thanks
This works with some dvd players, don't know if it'll work with yours... With the remote, open the tray... punch in 9,9,9,9...and then enter, and then '0' and hit enter again. This breaks the region code or allows playing of any disk.
Jan 06, 2011 | Teac DV-H500 DVD Player
I have this exact problem!
I found a couple of region 1 DVDs and tested them in the player they worked so that's the solution?!
Jun 19, 2009 | Teac DV-3000 DVD Player
When playing a DVD, picture & audio stop for a second one a while, no problem when playing a CD
this may just be the mechanism changing diretion as it reads the second layer on the disc usually because the film is too long to go on one side of the dvd disc.
quite normal.
but if happening quite a lot during playing a film then it could be something as simple as cleaning the mechanism. NOT for the untrained
Jun 01, 2009 | Teac DV-H550 DVD Player
DVD player trouble after new laser pick-up
ok, this is a compatibility issue.try looking at the lens but not directly if it lights on when loading a disk.if ok.make sure the ribbon wire is securely attached especially the the terminal are not folded.
May 28, 2009 | Teac DV-H550 DVD Player
Teac Remote control
TEAC do not and will not divulge their intellectual property
Aug 22, 2017 | Teac DV-H550 DVD Player
Unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
  1. Open the disc door
  2. Press Setup, Vol +, Vol -, Vol +, Vol - on the remote control
  3. Press < or > on the remote control to select the region code (255 is all regions)
  4. Press 'enter' to confirm
  5. Close disc tray
Hope this helps.
Miche
Jun 12, 2008 | Televison & Video
Teac PD-H500 CD Player Logo
223 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
