Question about Samsung SyncMaster 203B LCD Monitor
How to rotate display when I rotate screen - SyncMaster 203B
I have a Samsung SyncMaster 203B Monitor. I can rotate the screen to display a full page. How do I rotate the display?
You ought to be able to bring up the video card settings from your control panel and change it there. For instance I have a nVidia graphics card. When I bring up the settings panel it offers me the opportunity to change the rotation there.
Posted on Feb 07, 2009
Nothing on the screen
if their is a an power indicator in the front but with out a display or black screen, the cause it could be a busted back light or dry joint connector for inverter board for screen back light.
Aug 15, 2012 | Samsung SyncMaster 203B LCD Monitor
I just bought a used Samsung SyncMaster 2243BWX LCD and plugged it into my Mac Book Pro (an older model) with OSX 10.4 The screen shows a display but it is shifted from the one on my computer with the...
There will be buttons on the front of the monitor where you can change the position of the screen, you could also do this in the display driver on your macbook although I couldnt tell you exactly how on that particular mac, pretty sure the menu onthe monitor will get it sorted though.
Oct 29, 2010 | Samsung SyncMaster 203B LCD Monitor
My samsung syncmaster 203b, the screen has just gone black with no picture but the power light is still on, i unplugged it and swapped it with my other samsung syncmaster monitor which is working but the...
This model is a great one and well worth repairing. The display problem you are having is caused by bad capacitors on the power supply board. To repair the unit you will need to replace 6 capacitors and one fuse on the board, this is very easy to do, it just requires a little soldering. Here is a picture of the power supply board with the capacitors and the fuse circled and here is a link to additional information on the capacitors needed.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Aug 12, 2010 | Samsung SyncMaster 203B LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung syncmaster 203b problem
This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
Apr 04, 2010 | Samsung SyncMaster 203B LCD Monitor
My monitor started to give me problems when I first turn it on I have to push the power button several times before it will stay on it's the samsung syncmaster 203b
you need your power supply reaired. the capacitors go bad. remove the covers and look at the power supply reeplace any leaking and or crowned capacitors
Jan 01, 2010 | Samsung SyncMaster 203B LCD Monitor
Syncmaster 203B LCD not working with Vista 64
I would first recommend reseting the bios, if the monitor still is black then it may be a problem with the graphics card
Dec 16, 2008 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
686 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
