Question about Samsung SlimFit TX-S3082WH 30" TV
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
The blurring on the left and right sides started a couple of days ago and is about 4" on both sides. Is there anyway to correct this or tweak it through the service menu or other option?
Any help would be appreciated. Thanks in advance.
Your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
Posted on Jan 19, 2009
Schematic SlimFit CS21B850F6
Schematic diagram is in PDF, and cannot upload by this window. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Oct 16, 2013 | Samsung SlimFit TX-S3082WH 30" TV
How to change tx-s3082wh black and white pictures to coloured
Check its color system settings. If the system setting is wrong, there will be no color.
Feb 22, 2013 | Samsung SlimFit TX-S3082WH 30" TV
TV doesn't come on. Checked fuse in power board and is not blown. Samsung Tx 2675W thanks Eric eshackelford@kqed.org
I could be the capacitors problem on your power supply circuit. Just has it checked and replace the defective one
Jan 18, 2011 | Samsung SlimFit TX-S3082WH 30" TV
My slimfit tv keeps shutting itself off and on
sounds like the power supply board has failed. common problem.
Nov 14, 2009 | Samsung SlimFit TX-S3082WH 30" TV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung tv probelem number 2
i have the same problem with mine too. I cannot figure out how to fix it. Any luck?
Jun 25, 2009 | Samsung SlimFit TX-S3082WH 30" TV
No blue color on tv screen
Your welcome ! please comment. Thank you !
May 01, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Blurry Picture
This is normaly due to the focus bias volts being out of spec, and slowly drifting in to specs. This type of fault is usualy in the high voltage multiplier section that supplies the focus voltage, or in the focus circuit on the the CRT circuit board.
There is also a possiblity that the CRT is going weak, and it is taking some time for its emission to come up.
The TV service tech can do some tests to determine whre the fault actualy is.
Depending on the age, manufacture, and model of the set, would determine the price and availability for parts. If the CRT is the fault, then the set would not be worth to service.
Jerry G.
Apr 25, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Picture Inconsistency (Blurring)
Keep in contact with Samsung or the repair depot, as they may hook you along till the warranty is up and then want to charge you big bucks. Ok if your not happy with this set, go back to the store where you bought it, and compair it with one they have on the floor. If there are not any, tell them your not happy with the set and see what they will do about it. If you get no where with them, contact Samsung directly and they are easaly found online. If you need a URL I will be more then happy to supply it. Good Luck
Oct 07, 2006 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit  TX-S3082WH 30" TV Logo
471 people viewed this question
Henry  Thomas
Henry Thomas
