Neither the battery or power light comes on when Acer Laptop is plugged in. There is green dust coming out of the plug that goes in the circular yellow plug that gets plugged into the back of the Acer. What happened? What is the green dust?
    Problem Solver:
  • 10 Answers
Most likely you shorted your power plug on *********** board I would think green dust is burned residue. Smell where you plug your ac plug to and see if it smells like burnt plastic?
Posted on Dec 28, 2008
  • Jim Crowley Dec 28, 2008
    ********* is m.o.t.h.e.r. board
How do i fix an Acer aspire 4730z that will not charge the battery and has the charge light no longer comes on, is the motherboard bad?
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Sep 09, 2012 | Acer Aspire Computers & Internet
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Power Problem. Sudden onset of laptop not coming
The most likely answer is the motherboard will need to be replaced. Here are some troubleshooting steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 14, 2010 | Dell Inspiron E1505 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
18 volt milwaukee batteries
You could try another battery if you have on(they only last for so many charges) or your charger could be bad. Try plugging it in to another outlet. Good Luck
Oct 15, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Acer Aspire won't start
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Jul 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
