Question about Brother IntelliFAX 560 Plain Paper Fax
Cartridge problems Ok so I have never had a faxing machine before andi am not very tech savvy so can someone plz help me..I was given this faxing machine and it keeps saying I need to change the cartridge so my ?'s are where is is?does it really matter for faxing anyways?and how do I know if my fax wet through other than calling and asking?lol thanks
  • b_ballplayer Mar 02, 2009
    When you put the new cartridge in and pull it out to go on the lower (cardboard) bracket how do you wrap it around it?? do you tape it on??
    Champion:
  • 320 Answers
PICK UP THE FRONT COVER YOU WILL SEE THE DRUN AND THE TONER CART THERE TAKE THE CARTRIDGE OUT AND GET A REPLACEMENT AT STAPLES OFFICE DEPOT AND MAKE SURE IT IS A OEM REPLACEMENT GOOD LUCK BROTHER SR TECH
Posted on Feb 07, 2009
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
FAX MACHINE WILL NOT PRINT OR MAKE COPIES. I GET BLANK PAGES ON EVERYTHING
try wiping the contacts on the cartridge itself and the cartridge holder with a DRY paper towel and then re-install it.
Feb 19, 2009 | HP 1040 Plain Paper Inkjet Fax
Can fax but can not recieve fax
YOU WILL NEED TO GO INT TO THE MENU SECTION. FIRST PRINT OUT A HELP PAGE. WHEN YOU GO IN TO THE MENUE SECTION, LOOK FOR WHERE IT SAYS EASY RECEIVE PRESS SET OR OK THAT WILL LET YOU RECEIVE GOOD LUCK BROTHER SR TECH
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a Brother Intellifax 885MC and cannot receive andy fax
PLEASE BE MORE SPECIFIC ON YOUR COMPLAINT, I CAN HELP YOU BROTHER TECH
Jan 12, 2009 | Office Equipment & Supplies
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hardver problem
tough call, depending on how much you paid for it, it may not be worth it ( unless they give free estomates).
open the printer, look at where the printer head goes into home position ( where it usually ends upafter printing)
there is a sponge on the bottom, it is suposed to make contact only after it goes to home position ( this is what keeps the contacts moist so they don't dry up)
is it making contact all the time ? ( cheat the switch with the door open)
if you are not tech savvy then better to take it to a shop and get an estimate
Dec 19, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
MURATEC F-520 ERROR CODE 04
This code relates to a Drum Cartridge Problem.
Check the cartridge is installed correctly or at least try another drum cartridge.
Oct 03, 2007 | Muratec F360 Plain Paper Laser Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
