Question about Whirlpool GD2SHGX Refrigerator
Hotpoint refrig makes ice but no water will come out
The frig makes ice but will not depense water for us.
  • jbflattop Jan 31, 2009
    I have the identical problem. The owner instructions comment that a possible cause is that the water resivor is frozen. If so, how could that be fixed? Maybe emptying the freezer, and set at the warmest setting?
    I appreciate anyones help.
  • 37 Answers
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Hotpoint frig cxs25gr freezing food
Have you tried adjusting the cooling level? Does it still freeze on other settings? Is this a new or older refer?
Jul 28, 2012 | Refrigerators
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Water stop depensing ice work but no water
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
http://www.fixya.com/support/t1247133-no_water
Copy paste link.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
GE older ice maker won't make ice
pull the cover of the front of the ice maker. there should be directions as to what way to turn the main gear (use a philips screw driver). advance the ice maker until it starts to run on its own. if water comes in at the end of the cycle then you need a new ice maker. if no water comes in check to make sure the fill tube is not frozen. if it is clear replace the water valve.
Good Luck,
Todd
Oct 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Oct 16, 2007 | Hotpoint HSS25GFP Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
142 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
