Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Polaris 280 - tank track keeps coming off
We bought a house with an IG pool about a year ago, and it came with a Polaris 280 w/track kit. The Polaris used to get off track about once a day. Now it will not stay on for 5 mins. How do we adjust it? Will a new track tire fix it? The pool and Polaris is only 2 years old.
  • Sid R Aug 19, 2012
    Excellent solution. Took me 10 minutes and it worked.
  • 4 Answers
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Posted on May 10, 2009
  • Kevin K May 27, 2012
    It took me about 20 minutes to complete this task that the pool store would have charged me $75 for. The track has stayed on and works better than new....it climbs walls and stairs with ease. Thanks for the awesome advice!!
  • Anonymous Mar 24, 2016
    I searched the internet and came across this repair...the trax no longer come off. Took about 10 minutes to complete!
I have the same one and the same problem. The pool guys were just here and fixed it. Remove the middle wheel between the two larger wheels that hold the track. Then adjust the tension on the track to were it is nice and snug. This should fix the problem.
Posted on Apr 23, 2009
I have fought with the track falling off for 4 seasons. I just completed the "best solution" from mfhall77 above. It took about 20 min. total. It seems to work great. I am not sure why, but now the 280 even gets up the steps and cleans them. It never did before. This solution has 2 things going for it. 1 -- it's pretty easy and 2 -- it works!
Posted on Jul 31, 2010
Try using the cleaner without the track kit.
My pool has a steeply sloping bottom and the standard 280 gets up and down just fine with tracks.
Good luck
Posted on Mar 08, 2009
I need pictures to do a plumbing on a booster pump for Polaris 280 Please help me out
The horizontal threaded end plumbs into the pool return line, and the vertical threaded end (on top) plumbs into the Polaris return line.
This is a dedicated return line for pressure side pool cleaners that has been pre-plumbed into the pool when it was built.
If you pool does not have that cleaner return line Polaris has a kit for an "over the deck" mount. Each installation is not identical and it would be best to have someone on site to set you straight. Most pool guys will stop by for a minute or two and show you "what connects where" at no charge (expect to be invoiced if it turns into a lengthy Q&A). Google image may help. The 280 is an excellent cleaner, good luck with the install!
Jan 13, 2013 | Polaris 280 In - Ground Pool Cleaner with...
One of the wheels fell off. is this covered by the warranty. Just bought 3-4 months ago. how do i fix it?
There is only a 1 year warranty on a Polaris 280 (5 year parts warranty on the frame itself)
If you are the original owner you will need to take it into a local service company, preferably the company you purchased it from.
Be sure to register the cleaner at:
http://www.polarispool.com/registerproduct.aspx
As far as fixing it, Depends on how and where it fell of from.Did the axle break or it just became loose.
If the problem is that the screws were just loose, you can take the top cover off and look inside. Each axle is held on with 2 screws. Simply screw them back in.
I hate to sound negative but, I doubt that is the problem. This sounds like a broken axle, or even a broken wheel.
Polaris is great with their Warranties, so have no fear in taking this in!
Thanks for the question! I hope I helped you as much as possible!
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 15, 2010 | Polaris 280 In - Ground Pool Cleaner with...
The polaris keeps toppling over. Float is ok no
on the rear of the polaris the jet is a swivel, it propells the polaris set it a 11:00 o'clock and it should travel level.
Jul 05, 2010 | Polaris 280 In - Ground Pool Cleaner with...
How do i change the axle of a polaris 280 pool cleaner. I am trying to change the axle on my polaris 280 pool cleaner. I can't seem to get the top off so that I can reach the screws to change it out. ...
Here is copy of the users manual for these pool cleaners. It has a detailed diagram of all of the parts that is pretty easy to follow. Find the section that you need to change and you should be able to see how to access it. Hope that helps.
http://www.backyardcitypools.com/images/Polaris/Polaris-280-manual.pdf
Oct 10, 2009 | Polaris 280 Black Pool Cleaner
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Front wheels don't turn
It's probably a damaged drive gear. Polaris was at one time giving out free repair kits for this problem because of the poor design of the original.
Apr 18, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
2,198 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
