Medion mim2230 just cut out now no power is going to it
The power lead has a green light on it which still lights up!! could it be a fuse gone in the laptop and if so where could i find the fuses
  • 2 more comments
  • Anonymous Apr 24, 2009
    It wont turn on and the red light is on but when i turn it on, it goes off and nothing happens!
    Someone help!
  • tecknic-i43 Apr 25, 2009
    laptop is totally dead no lights nothing . only the light on the charger comes on. could this be faulty dc in socket or faulty motherboard?
  • william60 Apr 30, 2009
    Same problem. Totally dead showing no signs of life and occured without any warning.
  • Dan rogers
    Dan rogers May 11, 2010
    I can't read the problem but it sounds like your computer might have gone into sleep mode
Its the daughter board it holds the power socket usb sockets and on off switch , common fault about 95 euros for the part if you can get one and a lot of work to replace solution is not to buy cheap laptops stick with a decent make will save you money in the long run
Neil
Posted on Nov 10, 2009
Mim 2230 wont turn on. If you replace the pannel under switch this should sort you out i have replaced 3 now with 100 percet success
Posted on Feb 01, 2010
Front parking lights stopped working. Checked all fuses with tester under bonnet and inside car. All fuses and relays etc tested aok. All other lights function well. I traced the parker lights green wire...
Not the switch, or the rears would not be working. Since the green wire powers the rear lights, it has power. So maybe it's the ground connection to the front lights, right? Do you measure battery voltage on the green wire at the back of the light socket connector? If yes, then try moving your negative lead to the w/bl terminal of the connector...
Jul 11, 2017 | 1999 Toyota Camry
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
When I pulled bed off ,wires were cut. I have 2 green wires cut making 4 ends, 1 black wire and one white wire. I assume the green go with green , but the black ground and white wire I am not sure where...
Use a test light and check which wire has power as you turn on each function. The ground can be checked with an ohm meter . Put one lead of the meter on a clean groung spot on the frame and test each wire with the other lead . The wire that shows infinity or 0 resistance should be groung .
Oct 22, 2010 | 1990 Chevrolet C1500
Medion monitor won't come on
inverter has gone .cheaper to buy another monitor
Apr 26, 2010 | Medion MD 7317 17" Flat Panel LCD Monitor
Hi can you advise me how I can reboot with the system recovery of a medion mim2230 notebook, or point me to the user manual. many thanks
If it has windows, you can use F8 at power-up to boot into safe mode. Then you can select system restore from the control panel.
Apr 06, 2010 | Computers & Internet
Hi i have got a medion mim2230 laptop. when i turn it on i get a page that comes up and says 'sorry for the inconvienience, but windows did not start successfully. a recent hardware or software change...
hi
i have had the same fault with my medion mim2230 and tryed everything you list and i now have put it down to a battery pack fault why i say that is i removed my battery and laptop works ok some i ordered a battery of
ebay and placed it in my laptop and now its ok but just to make sure
i put my old battery pack back in my medion mim2230 and it come up with the same fault again so turned laptop off and replaced my laptop battery with my new one from ebay and its working ok
May 14, 2009 | Medion md40298 Notebook
I need to replace the keyboard on a medion mim2230 notepad. taken all the screws out of the back bey cant open up
Hi, You need to prise up the grill/cover that covers the speakers up and then side the keyboard up towards the screen, gently remove the plug to the Motherboard and you`re done.
Aug 13, 2008 | Medion Computers & Internet
Medion laptop mim2230
hi i need the driver for medion mim 2320 webcam
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
690 people viewed this question
David Payne
David Payne
