Question about Yamaha RX-V420 Receiver
Yamaha RX-V420 Will Not Power up
Last week I had the music nice and loud for a few hours and it shut down. I have unpluged everything and tryed to power it up and it only makes a clicking noise from a little red component just behind what looks to be the main power pack. I can only see one small fuse that i can see and it is fine other than that i dont know. Regards Daniel
  • Anonymous May 12, 2009
    no enciende se escucha el relevador de encendidi pero no enciende
I want service manual level 2,3,4
Posted on Jun 14, 2010
  • 1,074 Answers
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Posted on Apr 26, 2007
My Yamaha rx v 563 brand new used few hours only, doesn't turn on.all speaker's connected,.please give me yr valuable advices Thanks
Try holding the INFO and TONE CONTROL buttons and pressing power. This will release the protect lock. If it shuts back off, try disconnecting your speakers and try it again. You might have a shorted speaker or cable hooked up causing it to shut down.
Feb 21, 2017 | Yamaha Audio Players & Recorders
When playing the DVD when you turn up the volume the amplifier turns off.
Amplifier and an over load issue and is shutting down to protect the circuits. Needs to be checked out by tech.
Mar 08, 2015 | Yamaha RX-V420 Receiver
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Power on ok problem no sound !all transitor ok
Check this out. It is the most common problem I have found with these units. Along the lower left of the front panel the controls go from left to right Bass, Treble, Balance. Then Speaker A button and Speaker B button. Sometimes the speaker buttons get "unpressed". No joke, Check them out first.
If not. Then look for a short (even a frayed single conductor) in the speaker wires. On this model, it will shut down the output completely.
Hope this helps,
Dec 28, 2010 | Yamaha RX-V420 Receiver
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Oct 10, 2009 | Yamaha RX-V750 Receiver
Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Apr 21, 2009 | Yamaha RX-V2600 Receiver
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
May 12, 2008 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Receiver Logo
384 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
