Question about Uniden 5.8GHz Cordless Phone
The phone does not have a dial tone,but the corded phones do
I"ve tried taking out the battery on each phone and have just rehooked them up 30 minutes later, and am now recharging the phone. Previously the phones have continued in their docking stations, supposedly re-charging. My phones which have phone "cords" however, do have a dial tone, so I know that Comcast (the phone digital service) is working.
Hi my phone does not have a dial tone. I've tried taking out my phone from the charger but its off
Posted on Dec 29, 2008
I have a model KX-TG6445T PANASONIC 5 HANSET CORDLESS PHONE SYSTEM, THE PHON PHONE HAS NO DIAL TONE, AND SAYS PHONE IN USE. COMPUTER WORKS SO THINK IT IS A PHONE LINE AS THEY SHARE THE SAME LINE . HELP!
hi ... try this, change the cord in first.
if this don`t work: and make this test. whit another phone connected maybe in other place of the house(check first if you have dial tone ), plug the problematic phone, wait few minutes press talk on the other phone. if don't have dial tone the problem is the phone unit ,was impact by a lightning on the phone line.
few minutes after you connect the cord the line make a shortcut.
only an electronic technician can repair that, and sometimes is expensive.
Nov 30, 2013 | Panasonic Lands Phones
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
We cannot get a dial tone on all three of our phones. We tried unplugging them from the wall, taking out the battery and waiting 4 minutes then putting back the power source and putting in the batteries...
Have you tried a corded phone that does not have any batteries? Unplug all phones and try a phone with no batteries one jack at a time.See if you get dial tone on the phone with no batteries.
Jan 11, 2011 | Lands Phones
My Uniden answering machine and telephones cannot get a dial tone, I tried the reset recommended with taking batteries out of phones and unpluging for 30 minutes but did not solve the problem. After the...
has It been charged long enough and somthing I just found out tonight that the power cord must have enough power to make the base and phone work it tool me a month to find out But the power cord is the same brand as the phone so I assummed they belonged together but my phone needed 9v 300 ma
Oct 27, 2009 | Uniden Cordless Phone
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
No dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Dec 26, 2008 | Lands Phones
Will not call out!!! 25204RE1
I just encountered this same problem on my phone. To resolve, you must hard reset the phone as follows: unplug power cord, unplug phone cord, remove all batteries. Leave disconnected in this state for at least 10 minutes. Now reconnect in following order: reinstalling batteries, reattach the phone cord followed by plugging in the power cord. This restores the phone to the original settings. You will lose items in memory, but the phone dial function should be restored. This was recommended by customer service and resolved my issue which sounds identical to yours. You can now proceed with resetting up your phone as desired.
Jun 10, 2008 | RCA 25414RE3 Corded Phone
Wont dial
b-rad,
Try the follow steps and see if it helps:
  1. Take out the battery and wait 10 minutes.
  2. Put the battery back in.
  3. Place phone on charger for 20-25 minutes.
  4. Pick up the phone and try dialing.
Please let me know if this helps. Good luck!
Mar 02, 2008 | GE 25836 Cordless Phone
Medicom phone No dial tone
1podinker, you have a phone off the hook or a bad phone line. Plug a phone into the back of the modem and see if it works.
Bamachicky, need more info on what your modem lights are doing.
Dec 18, 2007 | Arris Touchstone 450a (CM450) Modem
Uniden 5.8GHz Cordless Phone Logo
200 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
