Question about Panasonic PT-47WX42 47" Rear Projection Television
Help :) My PANHDTV-53WX42F color went dark and I can not seem to get it lighter by using the menu options, also tried the convergence adjustments,, should I call a service tech or buy a new tv ??? Thanks !
I have determined that it is my green bulb that is bad, because it also controls a lot of the black/white picures, thus that I believe it is out this is causing the darkness. I went through all of the convergences through set up and altered/adjusted all the options in picture, not much changed other than the brightness of the pictures which at least makes it somewhat watchable. Have called a tech to replace bulb. Will let you know if it is anything else, but I must say for a "girl" I am getting very good at assessing a lot of mechanical issues :)
Posted on Dec 29, 2008
SD Tech: VERY dark picture with several black vertical bars
This set like most of these has 3 hidden Menu's=
1. Adjustments (stay out of that one)
2. Convergence (like the one in customer menu but better)
3. Option Menu**************
It will not correct the convergence circuit problem as those adjustments are stored in the Digital Convergence unit on the main board.
What it will do is a hard reset of the TV---everything back to factory original--can cure odd issues: no sound, video issues, you name it.
If you want I have found a site that has this for each of these sets--IT CAN ONLY BE DONE WITH THE ORIGINAL MITSUBISHI REMOTE.
I can get you a link to the site and manual for this set--since I never trust certain sites I do not download that manual but you can look at every page and copy paste to your computer the information needed for the OPTION menu and how to do it----stay out of adjustment menu as one wrong move and poof!
use the make a comment button to let me know what you want to do and I will help.
Mar 26, 2012 | Mitsubishi Televison & Video
My tv went multi colored take it as it looks like a 3d television
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Same problem with 53wx42f will kit work for this repair
What kit??? convergence kit???? If so YES
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Sony KP-46WT510 46 Some colors appear faded or washed out.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 31, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Picture has gotten darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Dark picture
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
