Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Dishwasher won't drain
I have a frigidaire 1000 precision control dishwasher and it won't drain. After each cycle there is still water in the bottom of the dishwasher tub. What do I need to do?
  • Anonymous Mar 11, 2009
    My dishwasher still has water in the bottom at the end of the cycle. I will drain it at the beginning of the next cycle I start...is that normal. This dishwasher seems to be Horrible at actually cleaning the dishes as well and I was wondering if it could be linked to the not draining.
How do you get the dishwasher to drain?
Posted on Mar 07, 2009
    Problem Solver:
  • 15 Answers
There's usually a filter cup around the bottom of the lower arm, did you check it? Look for kinks in the drain hose, if not it's most likely due to a blocked/faulty drainage pump.
Posted on Jan 08, 2009
Do I need a new drain pump?
Get a wet vacuum and hook it to the drain HOSE
May 29, 2015 | Frigidaire Professional Series 24"...
Why does by dishwasher not cycle through
The timer controls the electro-mechanical components in the dishwasher such as the wash pump, drain pump, inlet water valve and heating element. The timer also advances the control knob on the control panel. Replace the timer if it fails to start and stop the components properly or fails to advance the control knob. Dishwasher Won
Oct 26, 2017 | Frigidaire Dishwashers
I have a frigidaire FMB1100RHMO and first i was having a water problem and then i got the clog out. I have water pressure now but now it get stuck in the wash mode and dont come out unless i cancel it....
Hello Theresa Norman-Ramirez - Typically, it is normal for the dishwasher to delay the cycle and depending on the cycle and options selected, the cycle may last up to 4 hours. To reduce cycle time, turn on the hot water at the sink and allow it to get as hot as possible (between 120 F-130 F), then start the dishwasher. If the dishwasher cycle runs longer than 4 hours the main control board may need replacing. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 05, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
Water remains in the bottom of the dishwasher after cycle is over
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 06, 2011 | Frigidaire Professional Series 24 in....
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
244 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
