Question about Philips HDD100 MP3 Player
HDD 100/17 mp3
Hallo This player sucks when Imade a new installation of software and turned on the player it didn`t work The only message I got is an big EXCLAMATION mark (!) on the screen, please what to do? HELP !!!!!!!!!!!!!!!! regards henrik
  • 8,596 Answers
Re: HDD 100/17 mp3
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 19, 2008
0 characters
3 Points
I bought a Sylvania SMPK8854B MP3 player, but when i plug it in to my computer is says that the device is malfunctioning, but i just got it. and i didn't get any cd to install the software for this and...
Use an USB hub to make your connection. The USB controller puts out half an amp at 5VDC. The more things you have plugged in, sucking up that little bit of power, the more likely the next thing plugged in will overload the buss. A powered USB hub will give you the power you need to work with this unit.
Jun 15, 2011 | MP3 & Digital Media Players
My Phillips GoGear Vibe won't go to the main menu. It freezes up on the ViBE sequence. I tried soft resetting and turning it back on but it didn't work!
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
May 14, 2011 | Philips GOGEAR SA6045 MP3 Player
Connect to PC and use device manager to repair
If you have a Philips HDD Series, it will not work with Windows Vista or Windows Media Player 11 except for briefly, then the player will stop working one day. Your only hope is to use it with Windows XP and Windows Media Player 10 - it is, basically, an obsolete player at this point in time.
The Philips Device Manager has a strange feature - it only properly updates your device if you have the newest version of the Device Manager:
Download the newest version of the Philips Device Manager: - change your country/language as needed
-Tha Mp3 Doctor
Mar 30, 2009 | Philips MP3 & Digital Media Players
Sandisk is not detected in Vista operating system notebook
See the FAQ here -
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
View/c200: Turn on & press and hold the rewind button while plugging into the PC
Dec 30, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa e260- messed up
Download latest version of Quicktime
Oct 17, 2007 | SanDisk Sansa e250 MP3 Player
No system found on hdd
what if i don't the back up folder??? because mine came from my cousin abroad and not back was made.
Oct 08, 2007 | Kenwood HD20GA7 MP3 Player
Error message 800.... shows whenever I turn on sony connect player
sony connect is offline sony decided to stop trying to have an online music store... if that is your question
Jun 19, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Initial fail error
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Feb 17, 2007 | Samsung YH-925 MP3 Player
Samsung K5
Firstly, try "re-setting" the Z5 (ie micro switch) first. Then, remove the Samsung software (ie un-install) and try re-connecting the Z5 to your pc. If this works, download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
Oct 18, 2006 | Samsung Yepp YP-Z5QB MP3 Player
Philips HDD100 MP3 Player Logo
96 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
