Question about Yamaha RX-V2600 Receiver
Don't want turn on
I was listen music and the amplifier when off and don't turn on anymore
  • merlinp512 May 11, 2010
    What is the MASTER BUTTON?
Did u turn of the receiver with the "master" button?
Posted on Jan 15, 2009
I have an MTX audio JH 300 amplifier. When I turn the power off from the amp the yellow light comes on and stays on continuously. after about 15 minutes listening music amp shuts off, why
the light stays on because the amp is still storing power. it only turns off when the capacitors on the inside have drained off all the extra power
Oct 15, 2015 | MTX Car Audio & Video
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
Amplifier turns of at volume 2
Don,t turn it over 2 then,LOL: It has developed a internal problem end is going into what is called the protect mode. You will have to take it in for repair.
Oct 26, 2012 | Audio Players & Recorders
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
Yamaha RX-V2600 Receiver Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
