Question about Canon EOS Rebel XSi Digital Camera
Connected camera to computer before installing software
I made the mistake of connecting my new Canon digital Rebel XSi to my computer BEFORE installing the software. I just now read in the instructions that doing this will cause the software to not be installed correctly. What do I do now?
  • Ratherfly Feb 20, 2009
    I have the same problem, does anyone know how to reset this?
  • DRebel
    DRebel May 11, 2010
    hydeaway,
    What operating system are you working in? (Vista, Xp)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Nov 03, 2012
  • 58 Answers
SOURCE: Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
Posted on Sep 29, 2009
SOURCE: canon rebel xsi gets message card write protected
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
Posted on Oct 11, 2009
SOURCE: Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
Posted on Apr 26, 2010
SOURCE: My Canon Rebel XSi will not auto focus.
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Posted on Apr 29, 2010
  • 72 Answers
SOURCE: My Canon Rebel XSi screen will not turn on even
Does it take pictures? If it does, the display may be off, try pressing the DISP button a few times. If not, the camera may need to be reset, the battery may be faulty, or the camera may need to be serviced.
Posted on Jul 15, 2010
When I connect my Rebel XSI camera to computor using canon remote capture I egt the message take off lens cap or connect cable
One thing to remember, when you connect a digital camera to a computer, the camera has to be on, that is the only way the computer can get a signal from the camera. I favor taking the CF card out of the camera and inserting the card in my card reader built into my computer. That way I do not have to connect or disconnect the camera each time. So make sure that your camera is on before you call up your detection software.
Jan 01, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I am not able to connect the canon rebel xsi camera to my windows xp PC. intitally it was working. but now it is giving the message as "camera is busy"
Remove the camera memory card and use a card reader. Fit the memory card in the card reader and go in My computer. You will find there your memory card. Just open the memory card and copy them & then paste in the computer.
Aug 10, 2010 | Canon EOS Rebel XSi Digital Camera
Canon eos rebel xsi not detected by mac (but it was for a long time, now out of no-where, it is no longer detected)
the same thing happened to me, maby the camera has experianced a knock, try getting it seen to by a real person
Apr 19, 2010 | Canon EOS Rebel XSi Digital Camera
Connected canon rebel before installing software
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Feb 27, 2010 | Canon EOS Rebel XSi Digital Camera
Cannot download pictures Canon Rebel Xsi
Create a folder on your desktop. Use the cardreader to download to it.
Aug 29, 2009 | Canon EOS Rebel XSi Digital Camera
Computer don't recognize the Canon EOS XSi
Jul 21, 2009 | Canon EOS Rebel XSi Digital Camera
Can't download with EOS Utility
Try to change connection type to PC on camera menu. Maybe you have a print/ppt connection set.
May 31, 2009 | Canon Digital Rebel XSi Digital Camera
I am thinking of buying a Canon Rebel XSi for my wife - is it compatible with iMac computers?
Yes, here is the system requirements:
System Requirements for PC Connection
  • Operating systemMS Windows Vista , MS Windows XP SP2 , MS Windows 2000 SP4 or later , Apple Mac OS X 10.3.x - 10.4.x
    If this helps please rate my solution.
Dec 11, 2008 | Canon Digital Rebel XSi Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
177 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
