Question about Nikon COOLPIX L18 Digital Camera
Lense error indicator, Nikon Coolpix p50
Shutter will not close over lense
  • celliott70 Jan 20, 2009
    lens error msg and shutter doors won't close when powering off
  • Anonymous Apr 01, 2009
    sayes lense error on the screan
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 100,311 Answers
Try the procedures in this tip.
Posted on Jul 20, 2012
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Posted on Jun 21, 2008
  • 11967 Answers
SOURCE: My Nikon Coolpix s200 digital camera has a lense error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 03, 2009
  • 100311 Answers
SOURCE: nikon coolpix p50, lense error,
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
  • 100311 Answers
SOURCE: lense error
  • 1382 Answers
SOURCE: my coolpix S210 lense will not go in. Showing lense error on scr
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 27, 2010
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
My nikon coolpix p50 shows lens error all the time,how can i repair it myself?
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Nikon Coolpix P50 Digital Camera
Lens has turned red, takes red pictures
Unfortunately your camera sensor died. Taking long term video clips can cause this. It is necessary to change the sensor but it is not useful for your camera brand and model. Because your camera is chiper than this repair process. Not economic.
Feb 21, 2010 | Nikon Coolpix P50 Digital Camera
Lense Error
I have a solution for Nikon coolpix S5/S6. You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards Mukesh
Dec 30, 2008 | Nikon COOLPIX S6 Digital Camera
I have Nikon coolpix P50 does it support 8GB for SD card?
The manual only specifies cards up to 4GB in size. I suspect that Nikon, conservative as they are, only listed cards that existed at the time. If you can get access to an 8GB card, go ahead and try it.
You can download a PDF manual from http://support.nikontech.com/app/answers/detail/a_id/13948 and/or order a printed one from http://www.nikonmall.com/category/instructionmanuals
Jun 06, 2008 | Nikon COOLPIX L10 Digital Camera
Nikon coolpix p50, lense error, camera won't work lens stuck.
May 28, 2008 | Nikon COOLPIX L18 Digital Camera
Mar 27, 2008 | Nikon COOLPIX L3 Digital Camera
Image darkness
You might have to change your selected media choice. For example, if you are taking a close up picture you can select the face icon on the camera, etc. The problem is that the shutter isnt allowing that light to absorb in your lense which creates a darker image. You might have to use your flash or change the environment control to help the camera decifer where you are and what you are taking a picture of.. I own a D50 which is a Nikon, that is the same thing for me. I'm unsure of the coolpix, but typically you can point your lense towards ambient light to help the lense open up if its set to auto, then take the picture. Think of it as your eye, it needs that light in order to see.
Sep 13, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
141 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
