Question about GE Profile Prodigy DPSR513GA Dryer
Gas dryer makes loud noise when first started. noise level goes down after running several minutes
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fghgs
Posted on Sep 29, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
I get a loud scraping noise when I first start up the dryer
It sounds like the drum is off balance, the drum could be scrapping along the side of the dryer. Check for a loose bolt on the drum assembly. Once it starts running the drum levels out and the scrapping noise goes away
May 14, 2011 | GE DVL223GB Gas Dryer
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Loud dryer noise
heatman101
sfhgf
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Dryers Logo
231 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
