Question about Averatec 3200 Notebook
Spacer under spacebar broken
Can you get replacement spacers that fit under the space bar? Mine broke on my Averatec 3200 laptop and now I have to use a plugin keyboard?
    Problem Solver:
  • 5 Answers
You can order new keyboards for 20-35 dollars offlineand its a simple procces all you need is a small screwdriver (phillips) and about 5-15 minutes depends on how familiar you are with your hardware shoot me an email at austinlewallen@comcast.net and ill send some pictures guiding you if you want
Posted on Feb 28, 2009
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
My Dell Latitude D630 spacebar came off. Nothing looks broken, but I can't get it back on.
If the hinge parts are not broken and are still in place then place the space bar over these parts, align it so it is in the correct position then press the space bar down until the hinges click into the space bar.
Dec 15, 2012 | Dell Latitude D630 Notebook
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
I have canon ir 5800cn error 014 please any help
There is service bulletin that says:
Measures against noise, E014, and faulty fixing caused by coming off of fixing roller
Detail:
<Symptom>
The fixing roller comes off, leading to noise, E014, and faulty fixing.
<Cause>
Because the fixing spacer [2] does not rotate while the fixing roller [3] is rotating, the retaining ring [1] becomes
detached due to frictional resistance with the fixing spacer, and the fixing roller comes off as a result.
<Factory Measures>
A projection (P-2 [1]) is added to the fixing spacer. When attaching the fixing spacer, fit the projection in a
groove (P-3 [2]) of the fixing roller shaft so that the fixing spacer will rotate together with the fixing roller and
frictional resistance between the fixing spacer and the retaining ring will be eliminated. Therefore, the retaining
ring is prevented from becoming detached.
Service Work:
Replace the fixing spacer with the new-type fixing spacer when the foregoing symptom has occurred in the
field.
To prevent occurrence of the symptom, check the shape of the fixing spacer when replacing the fixing roller,
and replace with the new-type fixing spacer if the previous-type fixing spacer is attached.
<Point to note on attaching the fixing spacer>
Fit the projection (P-2 [1]) in the groove (P-3 [2]) of the fixing roller shaft to attach the fixing spacer.
OLD SPACER, FIXING FC5-2590-000
NEW SPACER, FIXING FC5-2590-020
Affected Machines:
iR C6800 EUR 230V JKH01022 and later
iR C6800N EUR 230V JKP02113 and later
iR C5800 EUR 230V KEN00106 and later
iR C5800N EUR 230V KES00135 and later
This is factory error, and I think that you must call service and have it fixed under warranty.
Hope that helped
Jul 01, 2010 | Canon Office Equipment & Supplies
My laptop seems to have the space bar stuck down.i have managed to remove the spacebar and nothing was wrong with it. E ven while the spacebar was removed the laptop thought it was being pressed down.its...
I have heard and did experience laptop spacer bar not registering when you press it.
I have a HP zv6000 with this problem, here is how I solved it, as it is a manufacturers design fault:
If you have the maintenance manual (get it of the web free), remove the key board. Place a small block of about 3/16" of folded paper between the underside of the spacer bar pad and the board itself. This it to help raise the spacer bar for the next step.
On the underside center of the spacer bar is a small black silicone rubber button, that may now have enough space between it and the underside of the spacer bar (after applying the sandwich of folded paper). The object of this is to enable you to place a 1/4" square of masking tape between the top of the silicone button and the underside of the spacer bar.
If this can be done, the tape will stay in place very well and in essence raise the spacer bar by the tape thickness, thus aiding in overcoming an unresponsive operation of the spacer bar. You may wish to place two thicknesses of tape in place for positive assurance. I only used one and it seems to work well, but I would recommend two thicknesses of tape, as the bar may still occasionally not register. But trust me it is much better now.
I'm sorry I did not take any pictures and I am not a member here, but I hope someone will find this very useful and post it for all to see.
Good luck to all.
Andy, Delta, Canada.
Jun 22, 2010 | Acer Aspire One PC Notebook
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Need to replace broken spacer on cutting bar
For parts give Royal a call at 1-800-524-0799.
Jul 10, 2009 | Royal Office Equipment & Supplies
Plug in is broke
you cant buy a new one..........
Oct 07, 2007 | Averatec 3200 Notebook
I need to replace my hard drive.
You have to remove the piece of plastic below the keyboard. the screws are on the bottom. becareful not to unplug anything else without notice how to replug the harddrive is behind the usb's. remove rubber spacer and unplug drive and then put everthing back...
May 12, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
104 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
