Question about Microsoft LifeCam VX-1000 Webcam
Webcam signal fails to reach other user
The image is seen here on the home computer but the people that I call cannot see me
    President:
  • 8,637 Answers
Send them this info.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
Blurred image
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied.
Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed.
The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu.
Aim the webcam towards you so that you can see the blurry image presented in the program's video window.
Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp.
Blow off the lens at the front of the webcam with compressed air.
Moisten the end of a cotton swab in photo lens cleaning solution.
Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge.
Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image.
Launch the webcam video program that is on the hard drive.
Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window.
Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field.
Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Aug 01, 2013 | GE EasyCam Webcam
Tip
ERROR codes Canon 8530
Canon 8530 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power -on. The surface temperature of the fixing assembly upper roller fails to reach 180 C within 5 min after it has reached 150 C. The surface temperature of the fixing assembly upper roller falls below 50 C in standby. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1,2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1.2) is being generated. E13 The error detection circuit on the waste toner feed motor driver PCB has detected on overcurrent. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after the power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the communication between the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error.
on Jan 19, 2010 | Office Equipment & Supplies
How to turn on my built in ebcam
Many Toshiba laptops, including Satellite, Portege and Qosmio models, feature built-in Chicony-brand webcams. The Chicony webcam can be problematic, especially when running a 32-bit version of Windows Vista. Microsoft has released an update that will correct problems with starting the webcam after terminating "Sleep" mode. Users may also have to install the appropriate driver or webcam software to correct webcam problems.
Dark or Black Webcam Image Problems b> Toshiba laptop owners may have problems with the webcam displaying as dark or completely black a few seconds after the initial image appears or immediately after engaging the webcam. Users should ensure that the webcam indicator light is engaged. If not, users should run the "Camera Assistant Software" to turn on the webcam. Low light can cause the webcam to power off and to display a dark image. Users can tweak the light and contrast by manually increasing the lighting in the room or by turning on "Night Mode." If these steps do not correct the dark image problem, users may have to reset the webcam itself, reinstall the "Camera Assistant" software. b> Webcam Problems After Terminating Sleep Mode b> Toshiba laptop owners with Windows Vista (any 32-bit edition) installed and the Chicony webcam may have problems starting the webcam after restoring the laptop from "Sleep" mode. "Sleep" mode powers down a number of hardware components in the laptop. The webcam is capable of entering a non-operating system-induced sleep mode when it is not used for an extended period of time. After the user engages Windows "Sleep" mode and wakes the laptop, the webcam may give error messages such as "Locked by another application." This webcam problem can be corrected by installing a Windows Hotfix, which is also included in Vista Service Pack 1 (SP1). Webcam Problems After Upgrading Windows Vista
Toshiba Satellite laptop owners may opt to use the Microsoft Anytime Upgrade to upgrade to Vista Ultimate. After doing so, the Chicony webcam may stop working and report a "Please turn on the camera" error message. Users can correct this problem by reinstalling the Chicony driver. b> Webcam Problems on Linux b> Linux users who own Toshiba laptops with the Chicony webcam should install the Linux UVC Driver to make the webcam functional. The webcam may not work without this driver. b> Grainy or Blurry Webcam Image b> The Chicony webcam can produce grainy or blurry images if the user does not remove the protective film that covers the external webcam interface.
http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions this will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps
b>
Jan 20, 2013 | Toshiba Satellite Computers & Internet
Web camera not working
Hope this helps
Nov 15, 2012 | Toshiba Satellite L505-S6955 (4400 mAh)
I dont know how to on my webcam I cant find any signal of webcam
Welcome to FixYa
Dear User,
Load the installation CD in computer. Choose your language, accept the licensing agreement and follow other on-screen prompts.
Connect the Logitech webcam's USB cable to your computer. A few minutes may pass while your computer detects its new hardware. A screen should then appear with an image from the newly installed Logitech webcam.
Follow on-screen prompts as the installation program performs an audio configuration.
Restart the computer and start enjoying your Logitech webcam.
Hope you got it.Dont forget to Rate[Let me Know if you need further assistance]..Thanks for Connecting FixYa...
Aug 20, 2010 | Logitech Webcam
The image from logitech E2500 qickcam is split into 4 vertically squashed images. It was installed from the CD that came with it. Any solutions welcome please. from Peter
Check you have no 'Fun Filters' selected - its the only place I have seen 4 split images on my Logi webcam
It will be within the 'Video Effects' menu ( 2 theatre masks )
Start your cam in 'Quick Capture' first ( 2 film frames with 1 head and shoulder pic )
Failing that I suggest you re-install from the website
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to download Microsoft DirectX 9 or later to support your webcam
Procedure
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Aug 06, 2010 | Logitech QuickCam Communicate STX Webcam
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
Web cam
This probably means that the icon is no good anymore. Are you using vista? Or xp?
You can probably do a computer search and find another icon on your computer.
1. In vista go to start and then just search "webcam".
In xp just run the computer search. If this didn't help we can try something else.
Jul 12, 2009 | Computers & Internet
I cannot be seen and heard by other webcam user
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 17, 2008 | PC Concepts 300K Webcam
Acer 5920
What program can I use to view, edit, or create images? Below is a listing of various software programs a user could use to view, edit, ... create web pages from those images, modify the images, and much more.
Internet questions and answers. CH000890, Can I view someone's webcam if I don't have one? ... CH000978, What services can I use to store and print my digital pictures.
How can I send messages to other computers? ... or even talk to other users using a webcam or using voice communication. ... Linux / Unix users can use one of the below commands to communicate with .
Good Luck, Read and follow instructions.Please dont for get to Vote/Thank You.
Dec 25, 2007 | Acer Aspire 5610-4648 Notebook
Microsoft LifeCam VX-1000 Webcam Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
