The volume in my Lincoln LSE (2002) goes off when I turn the steering wheel. Also my steering wheel radio controls are not working? can you help
After countless hours of research and nothing, I just decided to start playing around wtih the steering wheel. While in park I turned it all the way to the left and then to the right and low and behold the volume as well as the media steering wheel controls started working. I am sure its a loose wire but since money is tight this is a short fix for now.
Good luck to anyone else who may have the same problem.
Posted on Dec 30, 2008
Fuse is good horn still don't work
Does the cruise control, volume control and the other steering wheel controls work? This is likely the clockspring, which is located inside the steering wheel assembly
May 13, 2014 | 2002 Lincoln LS
Radio volume control on 2007 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
Nov 04, 2013 | 2007 Subaru B9 Tribeca
2001 Town and Country Steering Wheel Radio Volume Switch Broke
The circuit for the switch goes through the clock spring contact is the likely cause of the switch not working, it is not connected to the wiring harness in the steering column that goes to the radio.
Sep 19, 2012 | 2001 Chrysler Town & Country
Fix horn in 2002 ls
IF you horn isn't work. Does your radio and crus control buttons on the steering wheel work? My lincoln ls it started with the horn the the controll then the air bag on the steering wheel. There is a modual in the steering colum behind the wheel that controlls all of it. the part is about 145. or the dealership well charge 300 to fix it.
Jan 04, 2011 | 2002 Lincoln LS
Had to install a new battery in 06 Lincoln Mark LT, Now my radion volume and station select stopped working on my steering wheel. Do I need to reset something?
You need your owners manual, to reset what ever you lost
on the radio
I don't believe the wheel controls were lost
Check the radio to see if you have things set the way you want
There won't be anything you do for the wheel buttons
just the radio
Dec 16, 2010 | 2006 Lincoln Mark LT
AIR CONDITION NOT COOLING AT FIRST & HORN, CRUISE,RADIO ON SW
Sounds like the compressor is weak. Replace it. Check pressure when hot .
Jun 11, 2009 | 2002 Lincoln LS
The winshield wipers and steering wheel not working properly
Sounds like the wiper lever is broke on the inside of the colum.
May 18, 2009 | 2002 Lincoln LS
Steering wheel controls
change out the clock spring. i had this happen to me google the lincoln ls clock spring installation and then go to the dealership and purchase the part. it will run you about $138.
May 04, 2009 | 2002 Lincoln LS
2002 lincoln lse srs system code 32 can you tell me what the code is?
Driver Air Bag Circuit Resistance High. Most likely caused be a bad clockspring between steering wheel and steering column.
Jan 03, 2009 | 2001 Lincoln LS
53 people viewed this question
 Grubhead
Grubhead
