Question about HP Pavilion zd8000 Notebook
The lights on my Pavillion 8000 all come on when it is plugged in
With the exception of the power light. However, it appears that it is not recieving enough power to even boot the laptop up. When I unplug the ac adapter all light go off. When I got the laptop the battery would not hold a charge. So, before I spend a lot of money on replacement parts I would like to narrow it down. Any help would be great!
  • jdorigat Dec 28, 2008
    Yes, it is out of warranty.
  • HP Master
  • 5,568 Answers
I checked and reviews on your machine are mostly from 2006 so warranty is probably not a consideration any more.
If you are in the US, you can buy a digital multimeter for <$20 at auto parts stores, Radio Shack and others. If you are in the are where Harbor Freight stores are located, I have bought a few serviceable little meters for $3. These aren't precision instruments but they are very nearly as good as those I have that cost far more.  They come with somewhat intelligible Chinglish instructions and with it, you can learn a couple of things about your problem.
If the charger is plugged into AC, you can check to see if any voltage is available at the computer end of the cable. If it is rated at (for example) 12 volts, you could find anything from 13 to over 20 volts and this would mean the charger can do something.
Your battery pack could have 2 to 4 contacts on it on the end that plugs into the computer. With the meter set to 20 volts DC, you can check between all of the connections, two at a time, and if (again, an example) it is rated at 12 VDC, you should see at least that amount and it could be 13-14 volts depending on the kind of cells it uses.
I would do this test after sadly watching the LEDs all fade away since this means the battery is pretty much exhausted. A 12 volt pack removed after this will probably show several volts and climb while you watch it but that only means it is sick, sick, sick. If you find no two points that show some kind of voltage, an internal thermal fuse may have blown and if you aren't a techie, you will probably need a new pack.
So for a few dollars, you can gain knowledge as to what it is you really need; a battery pack or a charger.
Posted on Dec 28, 2008
    Sergeant:
  • 279 Answers
Is this an old laptop? If it's relatively new, I'd say send it back under the warranty and avoid the aggravation.
After re-installing Vista, cannot connect to internet
I assume that you installed the drivers after you reinstalled Vista.
The light is there to tell you that the wireless hardware is powered and active .
Your drivers are either corrupted or the wrong ones. If they appear in the Installed Programs then uninstall them and reboot at least twice with a registry cleaning in between.
Then go to
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3717592&prodTypeId=321957&prodSeriesId=3717590&swLang=13&taskId=135&swEnvOID=2093#11395
and download (as in Save, not Run) the drivers to a USB stick. Then plug that stick in your aptop and launch them.
Mar 14, 2010 | Tablets & eReaders
HP Pavillion DV6700 is shittung down
This could be numerous things. It could be an over heating problem, a virus, a power supply failing or something wrong in the power adapter on the motherboard where the power plug plugs into the laptop. If you plug in the laptop and see the battery charge light come on then the problem is most likely an overheating problem or a virus. If the battery charge light comes on then I would recommend taking it to a reputable repair facility to have them diagnose the problem.
Jan 01, 2010 | Computers & Internet
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
HP Pavilion 8000 power light and battery light blinking
hi,
Hp recalls some king of batterys, maybe yours it is on this recall, contact hp web or phone to take advantege of this recall, otherwise appears that your battery do not work you may replace it.
Thanks
vcrtech
Apr 27, 2009 | HP Pavilion dv8000t Notebook
Hp Pavillon 8000 laptop will not power up,
This is caused by a circuit breaker in your laptop. when it is overloaded it will kill the power on your computer. you might have a faulty cooling system internally and you need to take it to a shop to repair
Dec 03, 2008 | Computers & Internet
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Toshiba P20-771 motherboard
- Toshiba Quosmio G10-105
- Toshiba P20-771
- Hp pavillion 7259
- HP pavillion 7395
- Hp pavillion 8000
Jun 06, 2008 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
