SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
SOURCE: i have a 235e husqvarna with tool-less chain
Any weekday between 1300 and 1600, stop by McNasties, buy 2 premium coffees (one black). Continue on to your friendly neighborhood Husky dealer (leave the saw in the car) and present him with the coffee. Discuss the problem you are having and ask for his help. It appears to be possible to replace the tool-less setup with the tried and true version. I estimate $20-30. Probably less than repair cost for your current arrangement.
Is not new and improved wonderful? We found a way to simplify manufacture, use fewer parts, and negatively impact how well our product performs... You pay more!
This may also help Mr McKenna:
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week.
I hope this was helpful.
Lou
SOURCE: husqvarna chainsaw 235e starts but the chain won't
Does the brake seem to 'snap-over' like it should? Pull it back to release position, and remove the drive cover. Check the entire brake for debris accumulation or bent/damaged brake band. Check the chain to see if it is being oiled. Remove the bar/chain and clean the entire assembly, particularly the small oil passages in the drive end of the bar. Start the engine and watch for oil oozing out of the small side port where the bar fits. If ok, reassemble the bar/chain. If no oil comes out, investigate the oil pump, lines, and filter/valve in the oil tank. Mount the side cover, but leave the fasteners finger tight. (The chain teeth cut toward you on the bottom run) Tighten the chain until the lower run comes up to the bar, but can still be turned by hand. Tighten the fasteners and recheck the tension. Trip the chain brake and make sure it locks the chain, then release it and make sure it turns freely. Check the chain oiling by running the bar tip at speed near some cardboard--it should leave a thin line of oil on the board. Hope this helps!
SOURCE: how do i release the brake spring on a husqvarna
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or to a work surface,
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
SOURCE: husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
http://www.husqvarna.com/ddoc/HUSI/HUSI2...
