Question about Whirlpool Duet GHW9150P Front Load Washer
I have a front loader that won'tdrain all the way
I have a whirlpool duet frontloader wash machine that won't drain all the way. It is starting to smell like mildew and I can't figure out how to fix it.
Ok, my serviceman just left after fixing the problem.  First, as the manual states, you should check the hoses and clean out the lint, which my husband did.  What the manual doesn't tell you is that if you unscrew the front panel on the bottom (you need a special bit to do this), there is a round drain on the bottom.  It's about 3-4" in diameter, and has an impression on the front so that you can unscrew it.  You have to pull it out a bit under a bar so that whatever is stuck in there can come out.  Make sure you have a large container because when he unscrewed this round drain, about two gallons of lint-filled water came rushing out.  The other point is that he said that the drain pipe in the back should only be coming out about 4-6" because otherwise, the water can back up, causing that mildewy smell.  Hope this solution saves you the $120+ it cost me.
Posted on Oct 30, 2007
A way to determine if your drain pump/motor is weak or not functioning 1) clean your filter first then take the drain pump hose down from the inside framework of the machine, lay it out flat,drain to an outside source or to a floor drain (you get my drift--the water HAS to drain somewhere!) then run it through a normal wash cycle. If there are no further problems, then you have successfully isolated the problem. This solution is for a whirlpool duet model number GHW9100 LW1but is probably applicable to most other machines!
Posted on Aug 28, 2010
In my case the washer never drained for some reason. The washer wouldn't let me open it. Hence it wouldn't let me run the drain cycle. Because the machine forces you to check the clothes so you don't accidentally wash them twice I'm guessing. What you do to fix the problem is "UNPLUG IT" This resets everything and then it will let you run the drain and spin cycle. Worked like a charm :).
Posted on Jan 11, 2008
Get the "new and improved design" of the water drain pump. For an older GHW91003540 Duet machine it is Whirlpool part # AP3953640. Call Whirlpool at 1-866-698-2538 to see if they will send you one without charge. The whole smell problem is directly related to this drain pump which performs poorly and thus all the drain plumbing becomes mildewed (because it is full of water) and this nasty, stinky undrained water gets into the machine and pollutes your laundry. I recommend taking all this drain plumbing apart and washing it...you will see it is full of mildew. Once that is done and the pump replaced you will never have another problem so long as you use an HE low sudsing detergent and leave the door open so the grey gasket at the opening dries between loads.
Posted on May 09, 2007
    President:
  • 1,294 Answers
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean.
Posted on Apr 26, 2007
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet sport frontloader wont drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Washing Machines
What does it mean when a duet front loader washing machine flashes F02?
f02 mean that the drain time is to long check the drain pump filter that is behind the lower front panel
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Gray front loader washing machine
Check the drain pump filter for a foreign object and check your hoses for clogging or obstructions.
If there is nothing wrong with either of those, you will need to replace the drain pump.
Jul 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GWH9100LW1 Frontloader problem
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,471 people viewed this question
Dan Webster
Dan Webster
Sal De
