Slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
SOURCE: Gemmy James Brown singing doll-mouth no longer
String Behind Mouth On All 2002 Gem-my Dolls Breaks
SOURCE: Our Singing Bing Crosby Santa doesn't move his
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
SOURCE: two broken gemmy dean martin dolls how can i get them fixed
i looked through my local yellow pages and called a few electronic repair places. i finally found someone willing to take a look at it. sure enough they were able to fix it.i picked one up today and dropped the other off to see how they could do with this one now too.thanks you dolores metacarpa
