SOURCE: smelled mild burning, lost antifreeze - engine
You will want to replace that asap...I believe its the V belt.
For the 1999 Mercury Mystique Water Pump Belt on 2.5L V6 Engine:
Probable Causes: Belt: worn out, started slipping. Overheating caused by failure of Belt. Lost antifreeze: caused by failure of belt, not turning Water Pump Pulley, not circulating anitfreeze, which resulted in overheating.
Click on the following free direct Link. It has the Serpentine & Drive Belt Diagrams and Tensioners for your 2.5L Engine.
Scroll down the Page (about 1/3rd down) to Diagram #G99H08189, it shows the specific Water Pump Belt.
Note the Tensioner.
http://www.2carpros.com/car_repair_information/year/1999/make/mercury/model/mystique/1999_mercury_mystique_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
SOURCE: need to view a diagram of 2002 cadillac deville
Hello, That belt drives the waterpump, if the belt came off then you have a problem. Either the pulley on the tensioner is locked up or the waterpump is locked up. It may have destroyed the pulley on the camshaft that drives the waterpump. Remove the black metal guard that covers the large pulley. Hope this helps to get you started.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
