Question about Jenn-Air JED8430 Electric Cooktop
Jenn-air JED8430 cooktop
We have a replacement glass for the JED8430 cooktop and would like instructions to replace it. or is it too difficult and just call a technician.
  • nsjlater Jan 03, 2009
    thanks,
    we decided to have a technician come out and install it. it did look a little out of our capability!!
  • rcodepwr Mar 09, 2009
    I have a cracked glass cooktop and i want to replace the glass
    only. Can the glass top be ordered separately
    or do i need to buy the whole cooktop assembly.
  • 135 Answers
Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
Posted on Jan 01, 2009
I have a Cooktop Jenn-Air Model JED8430. The cooktop glass is broken. Would it be possible to change only the glass? If so, where could I get an other one ?
Yes, you can change just the glass. It is called the maintop assembly and usually starts at $275 and goes up. You will need to get the remaining 3 digits for your particular model in order to get the right glass. A good place to start looking would be: http://www.searspartsdirect.com/partsdirect/part-model/JED8430?pathTaken=modelSearch&prst=0&shdMod=JED8430
Apr 15, 2011 | Jenn-Air JED8430 Electric Cooktop
I need to replace the glass top on a jenn air JES8850BCS slide in range. How do I do it? Can it be done leaving the range in place or does it need to slide out for the replacement? Thanks.
It looks as if you need to remove the whole cook top to replace the glass top, incidently that is a 400 dollar item, so you have to take care. See: http://www.partselect.com/PartDetail.aspx?Inventory=2341162&SourceCode=5&ModelNum=jed8430#RepairStory
Apr 11, 2011 | Jenn-Air JED8430 Electric Cooktop
HOW DO YOU REPLACE BURNER SWITCHES? REMOVE ENTIRE UNIT FROM THE COUNTER TOP, OR IS THERE A WAY TO JUST REMOVE GLASS TOP TO ACCESS SWITCHES?
Take off the switch nobs and center grate, then carefuly lift the glass up/ start on one edge first. Have a towel or pillow to rest the glass once off it is around 250$ to replace glass!
Dec 22, 2010 | Jenn-Air JED8430 Electric Cooktop
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Ookware should I buy for a Jenn Air
i would avoid cast iron or nickle pans as they are heavy and coarse. i would recomend a nice stainless set with aluminum bottoms
Jul 05, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Buy just white cook glass
You need to replace the whole cartridge!
Jan 30, 2009 | Jenn-Air JED8430 Electric Cooktop
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Dec 26, 2008 | Jenn-Air JED8430 Electric Cooktop
JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
Nov 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
244 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
