Question about Matrix 226R (VPR226R) PC Desktop
My computer has no Audio Device. the speakers work fine.
I had the computer taken to Best Buy and they were able to fix it. They are out again and the control panel says no Audio device. How do I re add it?
  • 51 Answers
Have you tried Windows Update,
If not follow this:
Click on start --> Programs --> Windows Update and accept all updates.
Windows update scans what your computer has connected to it and will see if there are any out-of-date drivers and software. it will also download them and install them for you automatically.
When this is done, restart the computer and check then if the sound is working.
Posted on Dec 28, 2008
    Sergeant:
  • 279 Answers
What kind of computer is it? What OS?
If you're running XP, go to Control Panel and open System. In Device Manager, look for a device with a exclamation point or question mark next to it. If you find one and it says "Multimedia Device" or some such next to it, right-click on it and uninstall it, then reboot. Assuming this was some major PC manufacturer (like HP,) on reboot, Windows should find the drivers for it.
My packard bell is about seven years old and was fine until i had it fixed recently and was told that i would need to buy new speakers that could plug into the back of the computer as I needed a new...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Packard Bell (030069) Sound Card
I cant hear anything from my laptop acer3682wxci eventhough without hedset pls ..help to work this out ....thanks a lot....
if you are having problems with your sound
also
hope this helps
Apr 14, 2011 | Computers & Internet
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other...
also
hope this helps
Mar 31, 2011 | Labtec Pulse 424 Computer Speakers
Hi: I have your white Creature II(?) speakers. I was using them on another computer for years and they worked fine. I have since taken them off of that computer and hooked them up to a computer in my...
Move the speakers back to the first computer, to ensure that they still work.
Make sure that the speakers are getting AC power.
Check that you have plugged them into the "line-out" (GREEN) conector on the sound-card.
Check that you have not "muted" the sound on your bedroom computer.
Move the "volume-control" slider away from "minimum".
Open Device Manager on the computer, to confirm that your audio-device is fully-loaded into Windows, with the correct device-drivers.
Having any "unknown" devices is a hint that some device-drivers have not been loaded.
Oct 24, 2010 | JBL CREATURE II Computer Speakers
I tried viewing a tv program on line and for some reason there is no sound coming through my X-540 speaker system. I checked the power and connections and they all seem OK. I'm running Vista on a Dell 9200...
Here is a solution : On desktop go to ::
my computer----mouse right click----properties----system----device management. There you can find symbols for all devices that are already installed on your system . Scroll down until you find the definition of your audio device software , for example , if your audio driver software is a realtek then right mouse click on it , then you'll find disable , just disable it and then uninstall the audio driver software ! After that you should restart your system . When system started again , install the software again , and restart the system once again . Now you should hear the operating system starting tone .. If you didn't hear the tone , then go to device management again and enable the audio device once again .
good luck . rate if useful please !
Jan 27, 2010 | Logitech X-540 Computer Speakers
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Speakers not working, but cables all plugged in...
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Jun 21, 2006 | Dell A215 Computer Speakers
Matrix 226R (VPR226R) PC Desktop Logo
585 people viewed this question
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
