Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Mx1000 tripping out
Hi ,my mx 1000 is being weird it seems to have a mind of its own ,sometimes this improves with a change of surface but not for long ,in game my buttons dont always repond and I cant hold the thing steady??? I dont know if its a driver problem or what???? any Ideas???? ty J p.s its no different if I have otherstuff running at the same time im gaming or not !
  • garthcat Nov 27, 2007
    I have a similar problem that can best be described as the mouse "tripping out". The cursor doesn't jump accross the screen so much as just being erratic. This is most troublesome when dragging an icon. I never know where its going to wind up. I suspect the laser window might be dirty but I have no idea how to clean it. Any suggestions?
  • Anonymous Apr 04, 2008
    I have the same problem
As it turns out the base station was to close to my pc and the cord at the back was not in properly I sespect .
Posted on Nov 29, 2007
I had this same problem for a while, and found some information stating that if you've got it hooked up via USB, it can go wibbly sometimes. Mine used to jump around the screen, and in gaming, it translated to me all of a sudden looking up and to the left. If you still have the PS/2 adapter for it, try using that for a bit and see if it helps.
Posted on Nov 27, 2007
Hi for one make shure you have good battery and also double check the sensor for debris if you have done this try moving the reciever away from the comp to see if maybe it is interfering also if you have a cordless phone base near it try moving it to see what it does i hope these work good luck
Posted on Apr 26, 2007
SOURCE:
Tip
How can I clean a Logitech MX 1000 Bluetooth?
<p>The Logitech MX 1000 is a laser mouse that connects to your home computer. It is called a laser mouse, it uses an optical beam instead of a rubber ball navigation. Over time, the area around the package is dusty or dirty and affect the functionality of a mouse. If this is the case with the mouse, a quick cleaning to start working perfectly in no time. <br /> <p><br /> <p>1. Disconnect the mouse cable from the USB port of your computer and turn the mouse upside down. Note the lens optical beam in the middle of the bottom of the mouse. <br /> <p><br /> <p>2. Bang on the bottom of the mouse to get rid of dust and dirt that have accumulated near the lens optical beam over time. <br /> <p><br /> <p>3. Use microfiber cloth (a different substance can damage the lens) and clean the bottom surface of the mouse as well. <br /> <p><br /> <p>4. Let your nails along the sides of the rubber feet on the bottom of the mouse all the dirt that accumulated in the crevices to remove. <br />
on Jun 26, 2011 | Logitech MX1000 Laser Cordless...
MX Laser Cordless mouse will not charge
yes you will find the baterys need changing (for rechargeble one's). the front of the mouce pops up when u flick the switch underneeth
Dec 01, 2009 | Logitech MX1000 Laser Cordless...
Uncontrollable mose
Check if the surface you operate on is not reflective. Sometimes on reflective surfaces the light/lazer of the mouse is deflective that causes it to move.
Cheers.
Please rate.
Sep 28, 2009 | Logitech MX1000 Laser Cordless...
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
MX1000 Laser Cordless Mouse, setpoint doesn't seem to work
install mouseware in the cd ,that given when you buying
Jan 12, 2009 | Logitech 931249-0403 Mouse
MX1000
wanda
Strange, I just left logitech page for MX 1000 Laser Cordless Mouse. All they sell is the AC Adapter. Thought that was odd.
Their not selling replacement batterys, just the AC adapter.
Click this link: http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11197300
If you scroll down to the bottom of the page & look to the right there is a toll free No# you can call.
Still find it strange that logitech sells the AC adapter & not the battery. Make you think your battery is good & the adapter is bad.
Good Luck & kind Regards.
& please vote.
Feb 24, 2008 | Logitech Cordless Mouse
Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Nov 04, 2007 | Logitech MX1000 Laser Cordless...
Mouse wheel stoped scrolliing
I'm assuming the mouse tracking and buttons do work. If you have gone to the extreme of reinstalling the OS as well as the mouse drivers I would next suggest you try connecting the mouse to a new PC. If the problem follows you to the new PC you mouse is damaged and there is literally not much the user can do except: -make sure the bottom of the mouse is clean -Try a different mouse surface; some surfaces don?t react well optically. Try calling Logitech, you may still be in warranty and who knows you may get a nice tech who will work with you to replace it. Never hurts to try.
Jul 25, 2007 | Logitech MX1000 Laser Cordless...
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
131 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
